Author Topic: sat nav update  (Read 11023 times)
Offline mcmaddy
Re: sat nav update
« Reply #20 on: 28 August 2019, 17:56 »
They are supposedly tied to the chassis number of the car but how true that is I don't know. It's one of the many reasons why nav pro is better if you can justify the extra pennies.
Offline fredgroves
Re: sat nav update
« Reply #21 on: 28 August 2019, 21:11 »
Probably can clone the card easy enough - it probably has a volume label or a hidden file and I doubt if either will be a serial number, just something to say its the nav data.
Offline mcmaddy
Re: sat nav update
« Reply #22 on: 28 August 2019, 21:38 »
I'm sure it's an encrypted file of some sort although some people were buying 2nd hand cards back when I had my Tiguan and they were working. A brand new card which is unused will work no problems.
Offline jv
  • Administrator
Re: sat nav update
« Reply #23 on: 28 August 2019, 21:59 »
Time to make your fortune then as there's none on eBay  :wink:
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline sjw
Re: sat nav update
« Reply #24 on: 29 August 2019, 09:45 »
Tried making a full, direct image of the entire card including all partitions and dropping it onto another card - no dice. I reckon the car is reading the CID of the SD card, so if you got a card such as a Samsung Evo from, like, 2013 which can have the CID written then you might be in business.
Offline Finglonga
Re: sat nav update
« Reply #25 on: 29 August 2019, 09:58 »
You can NOT use any other card that the VW on. No if's no buts. It is as simple as that.
As for the update it is simple.
Download your maps from the above website.
While they are downloading go get the memory card out of the car.
Now create 2 new folders on your desktop, on named newmap one named oldmap.
When the maps have downloaded, move the zip file they are in to newmap folder on the desktop.
Using the tool of your choice (Winrar I use, there are many others free) unzip it into that folder. It may take a few minutes.
Insert memory card into reader (slide the "Lock" switch to unlock it) and copy everything from the card to the new folder named oldmap. That is your backup, just in case something goes wrong. Once it has copied from the card delete the files on the card or better Format it.
Now you can copy the files you extracted from the zip file onto the card. Once done remove card slide the lock tab back and insert in car. Turn ignition on and after around 30 seconds the new maps will appear on screen. Job done so you can now delete the 2 folders oldmap and newmap as you don't need them.
I have just updated my maps using the above method and always use that method. It really is easy to DIY with absolutely no cost.
Offline sjw
Re: sat nav update
« Reply #26 on: 29 August 2019, 11:32 »
As you say, the instructions are very straight forward. Download and extract the zip file. Copy the old contents off the memory card. Copy the new contents on in place of them. Stick it back in the car.
During the stage of copying the old data from the card, you'll see the format in which the card is expecting the new data (it wants the whole of the maps folder, including the folder - don't just copy the contents)
I'm inclined to disagree about the "you can't use a different card, no ifs or buts", though. There are clearly some restrictions in place, but as a pedant I feel obliged to say that there is probably some workaround, even if it is very difficult, and that would mean that there are ifs and buts  :wink:
Offline Catnapper
Re: sat nav update
« Reply #27 on: 29 August 2019, 12:20 »
Did mine last night about an 90mins all done.
Straightforward enough with original SD card
MK7.5 Indium Grey 19" Brescia Alloys
Offline fredgroves
Re: sat nav update
« Reply #28 on: 29 August 2019, 13:02 »
Its this almost certainly:
https://www.youtube.com/watch?v=rcIDAsU0plo
Obviously that is posted for technical interest value only and I don't condone copyright violation...
Offline mcmaddy
Re: sat nav update
« Reply #29 on: 29 August 2019, 14:01 »
If you buy a brand new unused card it will work but if you purchase a used card as Finglonga has said it won't work. Nav pro is totally different though.
