Author Topic: Mk7 passenger mirror query  (Read 3979 times)
Offline rajb
« on: 19 August 2019, 14:35 »
Hi all,
so recently purchased a 2014 GTI PP. Literally over the weekend the passenger mirror drop down for when in reverse seems to have started to play up. It moves when selecting reverse but only ever so slightly wheras before it went down considerable to show the curb side.
Any ideas why it would suddenly do this?
Thanks,
Raj
Offline sjw
Re: Mk7 passenger mirror query
« Reply #1 on: 19 August 2019, 14:54 »
Hi all,
Thanks,
Raj
Sometimes, they can play up. Simply reset it
1. Put the car in reverse
2. Set the mirror where you'd like it to be
3. When selecting Drive, the mirror should return to it's original position
Offline Gnasher
  • Formerly GnasherVXR
« Reply #2 on: 19 August 2019, 15:01 »
Have you changed which key you're using? This might be the reason it's changed - the other key is on a different setting.
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
Offline rajb
« Reply #3 on: 19 August 2019, 16:32 »
Ah cool will try that  :cool:
Offline rajb
« Reply #4 on: 19 August 2019, 16:32 »
Same key so will try the reset mentioned above.
Offline Jim_mk7.5
« Reply #5 on: 19 August 2019, 16:37 »
Think that is only for cars with electric memory seats?
Exterior mirrors (only for driver's seat with memory function): position, lowering while reversing
NOW - 330e M Sport
Offline Gnasher
« Reply #6 on: 20 August 2019, 09:07 »
Mine does it different amounts on different keys and I've not got electric seats. I'd guess that the memory they refer to is for the actual mirror positions, not the position of the reverse dip function.
Offline Jim_mk7.5
« Reply #7 on: 20 August 2019, 09:24 »
Ah, yes see what you mean. Never used the spare key to honest.
NOW - 330e M Sport
Offline davkav
« Reply #8 on: 20 August 2019, 09:54 »
I would say that you have accidentally adjusted it whilst the car was in reverse.
As others have said, stick the car into reverse gear, set the passenger mirror to where you want it for when you are reversing. When you then pull away in first, after about 5 or 10 seconds, the mirror will move back up the position you had set it for normal driving.
Offline rajb
« Reply #9 on: 20 August 2019, 13:59 »
Mine aren't electric but still do this drop on the passenger mirror.
