Author Topic: MK7.5 PP DSG 1st To 2nd Gear  (Read 6178 times)
Offline Grahamt
Re: MK7.5 PP DSG 1st To 2nd Gear
« Reply #10 on: 13 October 2019, 19:24 »
Noticed the same. Definitely slips the clutch as low speed. I notice it most when you pull out of a junction where you haven't quite stopped so it's still in 2nd and it seems to ride the clutch for a bit.
The other thing I've noticed if you are in M for any reason when cold it can thud a bit when going from 1st to 2nd. But doesn't do that in D.
Mine behaves exactly like this and in addition........
When in M and moving slowly in queuing traffic I like to stop unnecessary shifting of the dsg gearbox so try to plan the gears to suit traffic flow......if I hold in 1 for say 20 seconds on steady minimal throttle and then shift to 2nd it's quite a jerky change.........does it hot or cold......leave it in D and it's as smooth as usual.
I do exactly what you've described for the same reasons and get the same jerky change......not always though.
Golf 7.5 GTI, 2019MY, DSG, Atlantic blue, 90% rear tints.
