Author Topic: head unit change to nav model  (Read 13651 times)
Offline gaz0r
« on: 04 July 2019, 22:19 »
Hello folks,
just bought a 2014 Golf GTD and I did not manage to get a model with a head unit.
now I have found one on eBay here: https://www.ebay.co.uk/itm/12-17-VW-GOLF-MK7-GTD-RADIO-STEREO-HEAD-UNIT-SCREEN-DISPLAY-3G0919605D/264342900381?hash=item3d8c108e9d:g:QdcAAOSwyTNc77Z4
now will this just plug straight in and nothing else to wire up for the sat nav and it should start working and all the other features will work too?
thanks
Offline DanDuda48
Re: head unit change to nav model
« Reply #1 on: 07 July 2019, 02:04 »
Definitely not. You have Discover Media MIB most probably Gen2 which is 16.5cm [6.5"].
The ebay link is for the screen only, you need the unit as well.
Besides, it has component's protection, so it needs to be removed and coded by someone who knows what they are doing (like VW Retrofit in Redditch).
Not as simple as it may seem, but perfectly doable.
2018 Golf GTI PP White Silver; DCC, Discover Pro; Lane Assist & DLA; Parking pack; Climate windscreen; rear tints.
2016 Golf GTD Oryx white; DCC; Tech pack [=Discover Pro + Dynaudio]; Sport & Sound; Lane Assist & DLA; Parking pack; Climate windscreen; rear tints
Offline tom500
« Reply #2 on: 01 September 2019, 22:07 »
Any idea on rough costs?
Offline DanDuda48
« Reply #3 on: 01 September 2019, 23:12 »
Work about £100. And the cost for hardware depends on which head unit you will get.
Make sure you get Apple Connect/Android Auto, so that you can use Waze on your screen...
Offline fredgroves
« Reply #4 on: 03 September 2019, 16:22 »
Every Mk7 GTD has a head unit.
The car itself uses the display for various configuration items.
Show us a photo of what you have in the car... the thing above the gearstick.
Offline DanDuda48
« Reply #5 on: 03 September 2019, 23:29 »
Yes, the picture would be the safest way.
I assume it is Discover Media Gen2 6.5"
Offline DanDuda48
« Reply #6 on: 04 September 2019, 20:44 »
And let me add that MIB2 6.5” and 8” screens are interchangeable, so you only change the screens as both 6,5" and 8" use 800x480 resolution.
However, if you want to have 9.2" screen, you have to change the head unit, as it uses 1280x680 resolution.
But post the picture and we will be able to help you.
