Author Topic: Active Info Display  (Read 18856 times)
Offline fredgroves
Re: Active Info Display
« Reply #40 on: 01 July 2019, 22:48 »
Evo1986 said previously "HUD and innovission cockpit should be options"
So this:
https://www.volkswagen-newsroom.com/en/innovision-cockpit-3958
On the Toe-rag btw, the innovision cockpit is a 3600 quid option and the HUD another 1000...
I like the idea but 4600.... eeek!
« Last Edit: 01 July 2019, 22:51 by fredgroves »
Offline monkeyhanger
« Reply #41 on: 01 July 2019, 22:54 »
So this:
Give it 2 years - it'll be less than half that figure.
Offline trueblue_ips
« Reply #42 on: 05 July 2019, 17:46 »
I'm struggling with this having just taken delivery of my car with the standard set up. I've worked out you can't have the navigation displayed on the infotainment system and the AID at the same time.
The navigation on the AID is displaying with the big dials. How do I change this to show the smaller dials?
Also, silly question but how the hell do you turn the radio off? I've had to turn the volume down to nil.
Thanks
Offline Guzzle
« Reply #43 on: 05 July 2019, 17:50 »
Change to smaller dials by pressing the square 'ok' button on the right hand side of the steering wheel.
To turn the radio off without switching the head unit off simply select another source by pressing the media button.
7.5 GTD
« Reply #44 on: 05 July 2019, 19:06 »
Thanks @Guzzle, I must have tried every button except the OK one.
The smaller dials look better I think.
When displaying the Nav, is there a way of getting it to show the gear selected on the left dial rather than what I assume is elevation?
Offline Guzzle
« Reply #45 on: 05 July 2019, 19:21 »
If you use the left and right toggle on the right of the steering wheel and go into 'views' you can configure the centre of the dials. I have mine in 'consumption and range' which shows a small gear indicator, but 'gear and speed' is also available.
7.5 GTD
« Reply #46 on: 05 July 2019, 20:03 »
Thanks very much, got it
One final question if I may - is it possible to change the volume of the sound actuator. I know it can be disabled completely but can you change the volume of it?
Offline Mutley75
« Reply #47 on: 05 July 2019, 20:05 »
Not directly.
But you can change the driving profile to Custom, which allows you to set Engine Sound to Eco which mutes it a little bit.
Golf GTi Performance Edition (2019), 5dr, DSG in Isaac Blue, Dynaudio & Brescia alloys.
Offline Guzzle
« Reply #48 on: 05 July 2019, 23:11 »
Not directly.
👍exactly what i've done in mine.
7.5 GTD
Offline Jim_mk7.5
« Reply #49 on: 05 July 2019, 23:16 »
Not directly.
Or even Individual mode as it’s most commonly known as...  :grin:
NOW - 330e M Sport
