Author Topic: Brake drying  (Read 11387 times)
Offline Will2018
Re: Brake drying
« Reply #20 on: 01 October 2019, 01:04 »
They don't come on for the very gentle braking but do engage where stronger braking is required, eg the car in front quickly slows for a turn off. Seen it for myself on an unlit country road.
Offline fredgroves
Re: Brake drying
« Reply #21 on: 01 October 2019, 12:48 »
The bit that worries me is when it leaves part of the pads on the disc. This thing needs a VW solution, really, as once this happens the damage speeds up. Quite a number of people on here have had to replace rear discs and pads at silly low mileage.
The rear brakes are responsible for the adaptive cruise control and hence wear out quite quickly if you’re a fan of that.
Mine will need replacing at about 23,000 miles.
I'm not convinced the brake wear that some talk about is ACC.
I use ACC all the time. I did not have my rear discs replaced on my last Mk7 GTD in 67k miles.
My current Mk7.5 with 53k on it also has not had them replaced.
Offline Finglonga
Re: Brake drying
« Reply #22 on: 04 October 2019, 09:13 »
I am on 77k with original rear discs and plenty of meat on them still, pads were 63k I think or around there and also I use the cruise control regularly.
Offline fredgroves
Re: Brake drying
« Reply #23 on: 04 October 2019, 12:23 »
I wonder if the brake wear is actually more to do with low use rather than heavy use...
Offline Carbon VW
Re: Brake drying
« Reply #24 on: 04 October 2019, 13:19 »
in my experience it’s defo not from under use. I commute every day over 100 miles in spirited fashion so I would be of the thinking of very poor quality rear discs and pads on the early Mk7 GTi s. The Brenbos I just fitted are night and day in comparison.
Mk7 CSG GTi 6MF Stage 1, CSS backbox
Offline fredgroves
Re: Brake drying
« Reply #25 on: 04 October 2019, 13:28 »
100 miles a day and probably what, 300+ days a year.... 30k a year? Thats not underuse! I meant more like 50 miles a week...
Offline Jason b
Re: Brake drying
« Reply #26 on: 05 October 2019, 14:30 »
I Has new rear discs on my mk7 at 25 k. they where pretty bad at 13k at 3 years old / little use
Night blue MK7 GTI keyless winter pack nav camers etc very partial to a Ducati and a Fs1e.A serial Le Mans 24 attendee 13 starts in a row to date
Offline monkeyhanger
Re: Brake drying
« Reply #27 on: 05 October 2019, 23:33 »
Every time my R was in for warranty work or service, after my first service at 10k miles, I was told that the rear disks only had 3 months wear left and I should replace them. Same story in about 8 visits over the remaining 34 months of ownership.
I'm a light braker who preserves momentum whenever possible, without driving like a nun - either those rear disks are designed to have a tiny amount of wear allowance in the thickness, or they were taking the piss. 14 months old now, the brake disks all round look immaculate on my Polo GTI+, unlike the sh!tty, rusty, scored disks of my R - they were full of cosmetic corrosion almost from day 1.
Offline fredgroves
Re: Brake drying
« Reply #28 on: 06 October 2019, 10:59 »
I was wondering whether that was just a dealer p*ss take too....
Offline sjw
Re: Brake drying
« Reply #29 on: 06 October 2019, 11:25 »
Probably the same as an MOT where they just advise you of brake pads/tyres all the time for something to do and the hope you'll give them a few quid
