Author Topic: Thinkware F770 Dash Cam Installation??  (Read 7433 times)
Offline Tally Wacker
Re: Thinkware F770 Dash Cam Installation??
« Reply #10 on: 01 May 2019, 11:27 »
Cheers guys
Had a look in the manual & I can find the 12v socket/cigarette lighter fuse No F40 in my fuse box. Was thinking that one & maybe F23 the trailer charging cable but would need to check with my meter on that.  I know it's probably not a difficult job but it's my first try & I do not want to mess anything up so hoping I can do it myself & learn something from you guys etc. Is there a way to post pictures to this post so I can show you what my fuse box & manual says?  Thanks again.
« Last Edit: 01 May 2019, 11:52 by Tally Wacker »
« Reply #11 on: 01 May 2019, 11:35 »
« Last Edit: 01 May 2019, 11:49 by Tally Wacker »
« Reply #12 on: 05 May 2019, 08:07 »
« Reply #13 on: 05 May 2019, 08:17 »
Hi guys.
Thanks for your help but I give up.
Went for the install & using my meter located a constant & switched fuse, great I thought but no ... nowhere to earth the dash cam to, not a single screw to earth in or around the fuse box area!.
I wanted to do this myself & learn something for a change but hey ho guess it's not to be ..auto electrician it is then. ☹️☹️
Offline mcmaddy
« Reply #14 on: 05 May 2019, 08:57 »
Plenty of screws in and around the fuse box area. I think mines in one behind the fuses that you can get to from the side once the side panel is off.
« Reply #15 on: 05 May 2019, 10:31 »
If I could work out out to post a picture of my fuse box you would be able to see what I'm up against.?
Offline mcmaddy
« Reply #16 on: 05 May 2019, 10:39 »
I've got the same dash cam fitted in mine and you have enough screws in and around the fuse box area to ground.
« Reply #17 on: 05 May 2019, 10:47 »
Ok thanks, but unfortunately the only screws I can get access to are the screws holding the plastic surrounding box, I honestly cannot see any screws that are going into metal etc. How do you post a picture on here please??
