Author Topic: Car Tracker Advice  (Read 4120 times)
Offline mcmaddy
Re: Car Tracker Advice
« Reply #10 on: 21 January 2019, 20:13 »
If you keep both your keys in Faraday pouches they can't use the relay method.
Offline Adam T7
« Reply #11 on: 21 January 2019, 21:04 »
I have key entry and a  Disklock
Offline Ryan90GTI
« Reply #12 on: 21 January 2019, 22:44 »
Search Autowatch Ghost on Google.
Offline Arrius
« Reply #13 on: 22 January 2019, 07:06 »
The problem with GPS trackers is they are easily blocked with a £10 gadget that plugs into the cigarette lighter. If you want a good tracker you need to be looking at Cat5+ trackers which are VHF/GSM/GPS.
[/quote]
I keep hearing about VHS supported trackers a lot lately, apparently they are excellent against thieves that use jammers. I will definitely check them out and yea Faraday pouches are a must now.
Offline fredgroves
« Reply #14 on: 22 January 2019, 09:29 »
[/quote]
VHF I assume you mean...
And anything in this area is cat and mouse. If enough people switch to VHF, then a blocker will become in common use for that too.
(I did just write a long piece on how you'd do it, but decided that documenting it wouldn't be a smart idea, but take it from me, its possible)
