Author Topic: Centre of tyres worn 3-1-3mm  (Read 8803 times)
Offline mcmaddy
Re: Centre of tyres worn 3-1-3mm
« Reply #10 on: 24 December 2018, 10:37 »
Just checked four different websites this morning and got four different recommendations ranging from 35 all round to 41 all round.  :grin:
Online Watts
« Reply #11 on: 24 December 2018, 10:52 »
The label for my 2015 GTI:
I run 19s so it is 41 all round which I've always done and had no uneven wear. First set of tyres was spot on all over after 20k miles having regularly rotated them. They still had a bit more life in them but I changed them as it was winter.
Previously:
Offline dubber36
« Reply #12 on: 25 December 2018, 07:31 »
That's a case of high recommended pressures to lower emissions. 19's are heavier and create more drag, so they suggest higher pressures to overcome this. From a weight bearing point of view, there's no reason why the pressures should need to differ from those for 17 and 18" wheels.
Offline fredgroves
« Reply #13 on: 27 December 2018, 08:55 »
usually get 16k out of fronts over double out of rears.
Only 32k from the rears? I had 60k+ from the OEM BS rears on my last GTD.
Only super noisy inside edge feathering made me change them - the rest of the tyre had plenty left to spare.
A Mk7's (front wheel drive) rear is so light that it hardly eats tyres at all.
Offline Finglonga
« Reply #14 on: 27 December 2018, 10:56 »
That's all I could take from the Bridgestones, they came off with loads of life left. But they were noisy and from new had terrible grip.
Offline fredgroves
« Reply #15 on: 27 December 2018, 11:42 »
Yeah I learnt my lesson from my Mk7 and this time swapped the OEM BS rears with the fronts when the fronts wore out...
Almost there now... and goodbye to Mr BS.
Offline Daz Auto
  • Other brands of washing powder are available.
« Reply #16 on: 27 December 2018, 11:42 »
Thanks for all the replies.
I have my winter tyres on at the moment. The car is more floaty and I can feel it moving around more in the corners without pushing it. The door sticker recommends 41 psi for M+S (winter) tyres. I have them at 38 psi and can't decide if I should try 41 psi or 35 psi :huh: Though I doubt if the tyre pressure would make winter tyres feel any better either way. :undecided:
I was going to put all 4 Bridgestone tyres back on the car for summer. Now I'm thinking of putting the remaining PS4 tyres on the rear and use the Bridgestone tyres on the front to wear them out faster.
10/8/2017 - GTI Performance, Red,5dr DS
Offline mcmaddy
« Reply #17 on: 27 December 2018, 11:53 »
Try 36 psi too.
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« Reply #18 on: 27 December 2018, 17:02 »
I run 36psi
Offline DanDuda48
« Reply #19 on: 02 January 2019, 02:45 »
<I was going to put all 4 Bridgestone tyres back on the car for summer. Now I'm thinking of putting the remaining PS4 tyres on the rear and use the Bridgestone tyres on the front to wear them out faster.>
That seems a wise decision, DazAuto.
And once you finish all Bridgestones, stick with Michelin. Makes a world of difference.
P.S. My Bridgestone Potenza S001 have done 17k and are all 5 mms front & rear (I am rotating them). So they will still last for a while... :-(
« Last Edit: 02 January 2019, 02:57 by DanDuda48 »
2018 Golf GTI PP White Silver; DCC, Discover Pro; Lane Assist & DLA; Parking pack; Climate windscreen; rear tints.
2016 Golf GTD Oryx white; DCC; Tech pack [=Discover Pro + Dynaudio]; Sport & Sound; Lane Assist & DLA; Parking pack; Climate windscreen; rear tints
