Author Topic: Creaking Suspenion  (Read 12670 times)
Offline 7MAT
Re: Creaking Suspenion
« Reply #20 on: 05 December 2018, 11:09 »
After hitting a pot hole and blowing a tyre I had quite a few rattles and creaks from the front suspension.
In the end I had to replace the top mount (completely worn) and damper as bent.
So had the garage chuck in a new racingline engine mount and Superpro poly bushes all round and the car now drives like a dream.
MK7.5 Golf GTI Performance, 3 door, Issac Blue, DCC, Manual. Racingline Stage 1 OEM+, Remus Exhaust system, Sache Performance Clutch.
Offline 2007GTI
« Reply #21 on: 11 July 2019, 19:52 »
Im resurrecting this, as my creaking suspension is getting worse and my question still remains, are Bilstein B4s the cheapest OEM substitute still, to cure the dreaded Mk7 rear suspension issue?
Offline 2007GTI
« Reply #22 on: 13 July 2019, 20:33 »
anyone?
Offline Philb280
« Reply #23 on: 13 July 2019, 23:43 »
Well, after hassling my local,dealer I eventually got them to fit a new set of dampers, just under 1k miles and rattle was back - TBH it was still there on the drive home from garage so I took the plunge and bought some Bilstein dampers .
Only fitted them today but on a quick test drive all is quiet, been out again over roads that would normally have me cringing and reaching for the volume button but all seems good.
When I took the Sachs off I could feel the play in the piston not good after only 1000 miles - the Bilstein piston actually looks a slightly larger diameter.
I’m hoping this has cured it - fingers crossed.
I paid around £90:for the pair, was quoted between £85-100 to fit but after watching a couple of videos on YouTube and taking off the wheels for an inspection decided to have a go - first one was a learning curve (plus trip to shop for an 18mm socket) so took around 45 mins (excluding the shopping trip), did the other in under 30mins - fairly easy job and I’m no mechanic .
Offline Splashalot
« Reply #24 on: 14 July 2019, 04:39 »
Which Bilsteins?
And how is the ride compared to the stock Sachs dampers?
1972 Turquoise Superbug S; 1978 Miami Blue Golf GLS; 2007 Mk5 Tornado Red Golf GTI; 2017 Golf 7.5 Trendline Tungsten Silver 1.4ltr 110TSi with DAP; 2018 Tornado Red GTI with DAP.  All MT.  Current: 2021 Mini Cooper SE, British racing green.
Offline Philb280
« Reply #25 on: 14 July 2019, 07:47 »
I fitted - Bilstein  B4 damper part number  19-230559.
Ride doesn’t seem to be any different just quiet.
Offline 2007GTI
« Reply #26 on: 15 July 2019, 11:52 »
Thanks Phil!
Offline 2007GTI
« Reply #27 on: 15 July 2019, 14:37 »
Did you just do the rear, and leave the front stock?
Offline Philb280
« Reply #28 on: 15 July 2019, 14:59 »
Hi
Yes just the rear ones.
Offline 2007GTI
« Reply #29 on: 15 July 2019, 17:24 »
Thanks Phil.
I've found them online for £90 a pair, seems like a good value fix!
