Author Topic: Tyres fitted but damage caused.  (Read 14370 times)
Offline p3asa
Re: Tyres fitted but damage caused.
« Reply #20 on: 02 November 2018, 19:52 »
I'm with Booth on this.
After having  various alloys damaged over the years I now go to a wheel refurber to have my tyres changed.
They aren't going to spend days refurbing wheels to then damage them putting the tyres back on so they are perfectly placed for this.
I also looked into getting my own equipment to change my own tyres and its surprisingly not that expensive. Unfortunately I've no longer got the space or I think I would invest.
Offline mcmaddy
« Reply #21 on: 02 November 2018, 20:07 »
I thought the same but if I'm only changing tyres every now and then it's a bit expensive to keep the equipment.
Offline Guzzle
« Reply #22 on: 02 November 2018, 20:10 »
They're about £500 or so on eBay for a semi-automatic tyre changer. I have the same issue, not enough space, otherwise I'd seriously consider it. Along with a steel wheel and a worn tyre to practice with. No way would my first attempt be with my diamond cut wheels!  :undecided: :embarrassed:
7.5 GTD
Offline mcmaddy
« Reply #23 on: 04 November 2018, 00:31 »
Thinking of buying a set of Cadiz rims and sticking some Bridgestone A005 all season tyres on instead of full winters. The tyre labels for the winters are really bad where the labels for all seasons are much better.
Offline Snoopy
  • Geoff.
« Reply #24 on: 04 November 2018, 08:10 »
Sorry to read this and i know how hard it is to find a good tyre fitter. I always take photos and dread what may happen. Gladly I have finally after years found someone who knows what hes doing and is a true car guy and as picky as me. I can pass on his details if you want for the future.
Current Garage:
35+ years of GTI ownership.
Offline mcmaddy
« Reply #25 on: 04 November 2018, 08:36 »
Thanks Snoopy, yes that would be good. Would be good to have someone taking care of the wheels instead of botching things up.
Offline wantmygti
« Reply #26 on: 04 November 2018, 13:59 »
Not sure those machines will spin the wheel to determine the new balancing weights? So you either need another machine or you’d still be stuck going to a tyre changer. Sadly the diy route become cost and space prohibitive.
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline Jim_mk7.5
« Reply #27 on: 04 November 2018, 19:20 »
As most of us live in a country where Winters are not obligatory, nor really necessary unless we live out in the sticks, the wheels VW supply suit most of us all year round, so they're meant to do UK Winters too.
Eh? The wheels VW supply? Assume you mean tyres - which are summer tyres. Got nothing to do with living in the sticks. More about safety as for 4-5 months we get temperatures regularly below 7 degrees. Which is when summer tyres (which probably about 98% of the Uk are driving around on all through winter) stop working properly. They aren't a necessity by any means but probably would reduce the amount of accidents that happen. I've never bothered but tempted this year.
NOW - 330e M Sport
Offline Watts
« Reply #28 on: 04 November 2018, 19:56 »
Down here in the beautiful, warm, sunny south, the temperatures do drop below 7 but not as often as you might think. We've had a couple of cold mornings recently but daytime is often up to 13c. Last winter I was considering winter tyres but held back and really I don't recall many days at all where they would've been good to have. There wasn't that many times that the roads were gritted either. I do take it easy but in nearly 35 years of driving there's probably only been a few times when it would've been a real benefit. Global warming perhaps?
Previously:
Offline p3asa
« Reply #29 on: 04 November 2018, 22:23 »
By the time family and friends want to use you, you'll soon recoup that money.
