Author Topic: Coolant Level  (Read 4002 times)
Offline mcmaddy
Coolant Level
« on: 07 July 2018, 20:08 »
Noticed this morning that my coolant level is below the minimum level but not sure if it's supposed to be like that as the car hadn't been started. Is it a cold engine check or is it to be checked once the cars on? I've got some old G12 ++ unopened in the garage but was thinking of just buying some from eurocarparts. Triple GX I think it's called but it's G13. They do two a ready mixed one and a non ready mixed one. Which one would be best to buy?
Offline Watts
Re: Coolant Level
« Reply #1 on: 07 July 2018, 20:32 »
This - http://www.volkswagen.co.uk/owners/how-to-guides/basic-maintenance#overlay-close says to use premixed G13. Since you can only top up when cool I'd say you can only check when cool.
Previously:
Offline Restlessnative
Re: Coolant Level
« Reply #2 on: 07 July 2018, 20:39 »
I used the Triple QX G13 from Eurocarparts.A 1ltr ready mixed 50/50 bottle was only a few quid.Only had to top it the once not long after i bought it (common factory filled problem).
Current: Golf GTD MK7  3 door manual carbon grey.
Offline mcmaddy
Re: Coolant Level
« Reply #3 on: 07 July 2018, 20:43 »
Cheers chaps
Offline Ulysses31
Re: Coolant Level
« Reply #4 on: 07 July 2018, 21:24 »
Just went to buy some and noticed the 35% off online code for this weekend only. Unfortunately, here's the list of excluded items. Would have been easier to list the items that ARE in the sale.
Shock Absorber Kit
Spoiler
Sports Silencer
Lowering Kit
Sump Plug
Anti-roll Bar Stabiliser Kit
Flaring Kit, wing
Performance Brake Disc
Performance Brake Pad Set
Electric Horn
Air Filter Element
Fully Tailored Mat Set
Sports Clutch Kit
Steering Box
Big Brake Kit
Brake Hose Kit
K&N Oil Filter
Locking Wheel Kits
Performance Lighting
Performance Bushes
Per Suspension Kit
Performance Tyres
Silicon Hoses
Suspension Kit
Wheel Spacers
Anti Roll Bar Kit
Performance Shock Absorber
Alloy Wheel
Dump Valve
Adjustable Sus Arm
ECU Superchips
Fog Lamp Bulb
HID Kit
Stop Tail Lamp Bulb
Style Corner, Indictor Lamp
Style Headlamp
Style Rear Lamp
Performance Exhaust
Coilover Kit
Air Suspension Conversion Kit
Styling Door Mirror
Waterless Coolant
Performance Radiator
OBD Port Protector
Wind Deflector
Car Air Fresheners
Battery Chargers
Fuel Cans
Indicator Bulbs
CD Players
4" (10cm) Speakers
In Dash Sat Nav
Standard Sat Nav
Widescreen Sat Nav
Sat Nav Software
Sat Nav Software
Sat Nav Mounts
Brake Lights & Other Bulbs
Parking Distance Sensors
Polishers & Accessories
Xenon Conversion Kits
Speed Camera Detectors
Accident Recorder
Security Tracker System
Trailers & Accessories
In Car DVD Players
Bluetooth Hands Free Kits
Bluetooth Headsets
Reversing Cameras
Booster Packs
Standard Headlamp Bulbs
Upgrade Headlamp Bulbs
Tyre Inflaters
Tyre Foam
LED Bulbs
HGV & Truck Sat Nav
Motorcycle Sat Nav
1" Drive Deep Impact Socket
1" Drive Impact Sockets
1/2" Couplings
1/2" Drive Deep Impact Sockets
1/2" Drive Impact Sockets
3/4" Drive Deep Impact Sockets
3/4" Drive Impact Sockets
3/8" Drive Deep Impact Sockets
3/8" Drive Impact Sockets
Accessories
Adaptor Couplings
Air Hammers
Air Hose
Air Hose (Retracting)
Air Line Fittings
Air Ring Main System
Air Tool Kits
Angle Grinders
Blow Guns
Buffing & Punching
Die Grinders
Drills
Engraving
Extension Bars
Filters & Regulators
Impact Extension Bars
Impact Socket Adaptors
Impact Wrenches
Key Sets
Nails
Oil
Polisher Consumables
Polishers
Ratchet Wrenches
Riveting
Sander Consumables
Sanders
Saws & Cutting
Saws & Cutting Accessories
Scalers
Screwdrivers
Socket Sets
Socket Sets
Staplers & Nailers
Staples
Universal Joints
Accessories
Belt Driven
Compressor Oil
Direct
Engine Driven
Specialist
Air Brushes
Air Kits & Accessories
Cleaning Tanks
Cutters
Dust Free
High Pressure Spray Guns
HVLP Spray Guns
LVLP Spray Guns
Masking Products
Panel & Trim Tools
Panel Dryers
Panel Stands
Sealant Guns
Sheet Tool Accessories
Spray Gun Accessories
Spray Gun Consumables
Spray Guns
Vehicle Stands
Body Repair Tools
Chassis Straighteners
Clamps & Measuring
Arc Welders
Inverter Accessories
Inverters
MIG Accessories
MIG Consumables
MIG Welders
Oxyacetylene
Oxyacetylene Consumables
Plasma Cutters
Plasma Inverters
Spot Welder
Stud Welder
Welding Accessories
Welding Consumables
Cable Shears
Detectors & Measuring
Hole-Saws
Levels
Measuring & Comparison
Miscellaneous
Pipe Products
Staplers & Nailers
Testers
Tiling
Wrenches
Punches & Chisels
Thread Cutting Tools
Workshop Tools
Brushes
Craft
Cutters
Extractors
Files
Hacksaws
Hammers
Levels
Mallets
Multi Tools
Nylon Faced Hammers
Pouches
Precision Tools
Pry Bars
Punches & Chisels
Saws
Screwdriver Bit Sets
Screwdriver Sets
Screwdrivers
Tie Downs
Workshop Tools
File Sets
Tap & Die Sets
Tool Kits
Air Jacks
Axle Stands
Bottle Jacks
Crane Accessories
Engine Stands
Engine Supports
Farm Jacks
Fixed Cranes
Folding Cranes
Jack Accessories
Jacking Beams
Motorcycle Lifts
Motorcycle Stands
Other Lifts
Ramps & Chocks
Scissor Jacks
Transmission Jacks
Trolley Jacks
Wheel Removal Trolleys
Beam Clamps & Trolleys
Chain Blocks & Hoists
Lifting
Amber Beacons
Booster Cables
Electric Winches
Hand Winches
Mobile Power Systems
Surge Protection
Tie Downs
Towing Accessories
Towing Aids
Trailer Accessories
Trailers
Accessories
Grinders
Grinding Discs
Sanders
Wire Brushes
Drill & Bit Sets
Pillar Drills
Consumables
Cut-Off
Hacksaws
Drill Vices
Engineering Vices
Mitre Clamps
Vices
Riveters
Shears
Battery Maintenance
Crimping & Stripping
Multimeters
Cutters
Driver Bit Sets
Hammers
Locking Pliers
Miscellaneous
Pliers
Precision Tools
Punches & Chisels
Saws
Screwdrivers
Wrench Sets
Ni Fe
1" Drive Socket Sets
1/2" Drive Deep Sockets
1/2" Drive Extension Bars
1/2" Drive Socket Sets
1/2" Drive Sockets
1/4" Drive Deep Sockets
1/4" Drive Extension Bars
1/4" Drive Socket Sets
1/4" Drive Sockets
3/4" Drive Extension Bars
3/4" Drive Socket Sets
3/4" Drive Sockets
3/8" Drive Deep Socket Sets
3/8" Drive Deep Sockets
3/8" Drive Extension Bars
3/8" Drive Socket Sets
3/8" Drive Sockets
Accessories
Adaptors
Allen Keys & Sets
Driver Bit Sets
Extension Bars
Mixed Socket Sets
Ribe Sets
Socket Sets
Spline Sets
TRX, Spline & Hex
TRX-Star Sets
Torque Screwdriver
Torque Wrenches
Adjustable Wrenches
Bit Driver Sets
Breaker Bars
Combination Wrenches
Crows Foot Wrenches
Flare Nut Wrenches
Flex Head Wrenches
Ni Fe
Nut Drivers
Ratchet Wrenches
Wrench Sets
Batteries & Chargers
Drills
Impact Wrenches
Polishers
Screwdrivers
Circular Saws
Drills
Grinders
Hot Air Gun
Jig Saws
Polishers
Accessories
Backing Pads
Battery Chargers
Compounding Heads
Cutting Discs
Drill Chucks & Keys
Flap Discs
Grinding Discs
Wire Brushes
Accessories
Removal Tools
Soldering Guns
Soldering Irons
Soldering Torches
Drill & Bit Sets
Air Conditioning Tools
Leak Detection Kits
Accessories
Battery Service Tools
Fuses
Testers
Headlamp Beam Setters
Laser Alignment Devices
Brake Bleeders
Brake System Tools
Cylinder Hones
Hose Pinch Tools
Anti Freeze Testers
Cooling System Tools
Hose Clamps
Leak Detection Kits
Water Pump Pliers
Analysis Tools
Diagnostic
Test Probes
Timing Lights
Compression
Cylinder Leakage
Fuel Pressure
Oil Pressure
Vacuum & Fuel
1/2" Drive Head bolt kit
Cam & Valve Tools
Clutch Tools
Diagnostic
Exhaust Tools
Fan Tools
Fuel & Injection Tools
Hose Tools
Hub Spanners
ID Tags & Clips
Pliers
Plug & Piston Tools
Pressure Testing
Pulley Removal Tools
Punch Sets
Spring Compressors
Stands
Stethoscope
Thermometers
Throttle Tools
Timing Belt Tools
Torque Gauges
VAG Tools
Wrenches
Accessories
Ball Joint Tools
Bearing removal Tools
Bearing Tools
Bush Removal Tools
Coil Spring Compressors
CV Joint Tools
Ford Tools
Hub Tools
Shock Absorber Tools
Drain Plug Keys
Oil Filter Crushers
Oil Filter Sockets
Oil Filter Wrenches
Gear Pullers
Slide Hammers
Alfa Tools
BMW Tools
Camshaft Tools
Chrysler Tools
Citroen Tools
Crank Tools
Diesel Engine Tools
Fiat Tools
Flywheel Positioning Tools
Ford Tools
GM Tools
Honda Tools
Land Rover Tools
Petrol Engine Tools
PSA Tools
Renault Tools
Rover MG Tools
Setting Kits
VAG Tools
Imapct Sockets
Specialised Socket Sets
Spline Keys
Star Keys
Thread & Bearing Tools
Air Knife
Door Hinge Pin Tools
Interior Tools
Moulding Release Tool
Panel Removal Tools
Trim Tools
Windscreen Tools
Air Line Gauges
Alignment Tools
Pressure Gauges
Pumps
Tyre Changers
Tyre Inflators
Wheel & Tyre Tools
Accessories
Consumables
Engine Cleaning
Mechanics Mats
MOT
Pliers
Prybars
Scrapers
Tweezers
Wing Covers
Car Covers
Cleaning Aids
Accessories
Vacuum Cleaners
Valeting Machines
Cable Ties
Staplers & Nailers
Air Presses
Arbor Presses
Battery Chargers
Battery Maintenance
Cleaning Tanks
Creepers
Fuses
Hydraulic Presses
Metal Benders
Pipe Benders
Seats
Shot Blasting Cabinets
Shot Blasting Consumables
Shot Blasting Guns
Solar Panels
Starters & Chargers
Tool Rails
110V Lead Lamps
12V Lead Lamps
230V Lead Lamps
Accessories
Batteries
Bulbs
Cable Reels
Extension Leads & Plugs
Flexi Lights
Floodlight Accessories
Floodlights
Generators
Inverters
Lanterns
Lead Lamp Accessories
LED Lead Lamps
Lighting
Magnetic Lights
Retractable Lead Lamps
Spotlights
Tool Transformers
Torches
Work Lights
Barrel Bunds
Diesel Transfer Pumps
Drain Pans
Drainers
Emergency Kits
Fluid Transfer Pumps
Fuel Cans
Funnels
Grease Guns
Measuring Jugs
Oil Cans
Oil Drainers
Spill Mats
Water Container
Drum Trolleys
Folding Trucks
Pallet Trucks
Platform Trucks
Sack Trucks
Workshop Trolleys
Pressure Washer Accessories
Domestic Pressure Washer
Engine Driven
Submersible Pumps
Suction Hoses
Surface Mounted Pumps
Body Protection
Ear & Head Protection
Eye & Face Protection
Fire Protection
First Aid
Hand Protection
Respiratory Protection
Workwear
Alarms
Barriers & Wheel Clamps
Cash Boxes
Key Cabinets
Lockers
Padlocks
Safes
Storage Cabinets
Middle Boxes
Mobile Workstations
Parts Storage
Plastic Toolboxes
Racking
Rollercabs
Tool Bags
Tool Cabinets
Tool Cases
Tool Chest Accessories
Tool Chests
Tool Storage Panels
Tool Trays
Toolboxes
Top Chests
Workshop Trolleys
Bins
Blowers
Brooms & Squeegee
Cycle Products
Dehumidifiers
Desk & Tower Fans
Drainage
Dust Extractors
Electric Heaters
High Velocity Fans
Hose Accessories
Infared Heaters
Kick-Steps
Ladders
Matting
Paraffin/ Diesel Heaters
Platform Ladders
Propane Heaters
Safety Steps
Step Stool
Tarpaulins
Ventilators
Water Hose
Water Hose
Vices
Vices
Workbenches
Workbenches
Hot Water Pessure Washer
Pro Vacuum Cleaner
Pro Vacuum Cleaner
Pro Pressure Washer
Pro Pressure Washer
Steam Cleaner
Steam Cleaner
Water Pump
Water Pump
Upholstery Cleaner
Upholstery Cleaner
Screw Compressors
Screw Compressors
Cordless Screwdrivers
Multi Tools
Multi Tools
Headlight Bulb
LED Bulbs
4" (10cm) Speakers
Car Air Fresheners
Accident Recorder
Blue Antifreeze
Red Antifreeze
Universal Antifreeze
White Golf GTI Mk7.5
Offline mcmaddy
Re: Coolant Level
« Reply #5 on: 08 July 2018, 09:06 »
Yeah noticed that the ready mixed wasn't included but the neat stuff is. How much is the VW G13 stuff? Ten quid??
Offline Mike J
Re: Coolant Level
« Reply #6 on: 08 July 2018, 09:16 »
When my car went in for its first service the tick list specified the coolant had been topped up so I asked the service manager if VW coolant had been used as a top up.
She had to go and ask the 'vehicle technician' for the answer and came back with the reply "around a litre of water"  :angry:
An online search indicated that Prestone Extreme Performance Antifreeze from Tesco's has the same spec. as the VW branded bottles so that is what I now use.
« Last Edit: 08 July 2018, 15:18 by Mike J »
Offline Finglonga
Re: Coolant Level
« Reply #7 on: 08 July 2018, 11:14 »
Basically everything
Offline kelvyn29
Re: Coolant Level
« Reply #8 on: 25 July 2018, 22:27 »
My coolant has dropped over last week, canr went in for 20000 mile service Tuesday, had a call Tuesday afternoon advising they have found a water leak and would investigate further.
Phone call today to advise found the problem which is the water pump, new one on order but wont be here until Friday.
Until then i have a 115bhp diesel loaner 😴
