Author Topic: 16v running like CRAP  (Read 10207 times)
golfvr6
Re:16v running like CRAP
« Reply #10 on: 28 October 2003, 18:18 »
Also check the hall sender in the distributor.
Offline Gambit
« Reply #11 on: 29 October 2003, 11:57 »
yes i've been advised to check this also for my erratic 16v (in mk2 forum)
but how exactly do u check it? what am i checking for? so far all ive done is take the 3 wires connected to it off and give then clean up
Offline Lee
  • Oiiii stop your dog sh!tting on my lawn
« Reply #12 on: 29 October 2003, 18:18 »
I have now been told to check my air mass sensor in the airbox. what is that and how do i check it works ok.
Ape shall never kill ape
Offline Lee
« Reply #13 on: 02 November 2003, 10:07 »
I forgot to say that the car only does this once it has fully warmed up.
free
« Reply #14 on: 04 November 2003, 09:08 »
have you tryed german sweadish & french (GSF) there a good place and cheep, you should have a shop ner you, if not they do mail order. or www.gsfcarparts.co.uk
golfvr6
« Reply #15 on: 04 November 2003, 09:23 »
Don't use GSF , they are muppets. Always go to VW if possible, genuine parts are always the best.
Offline Lee
« Reply #16 on: 06 November 2003, 12:51 »
How do i check the hall sender. Should i take the plug off it and see if it runs the same.
Offline Gambit
« Reply #17 on: 06 November 2003, 14:54 »
Lee, i've got the exact same problem as you, mine only does it also when its warm, it will miss inbetween 2800rpm - 3200rpm, and also the rev counter goes haywire sometimes bouncing all over the place. and basically run like a bag of nails - though the problem is v.intermittent
i couldnt understand why it only happened when it was warm, until i was told the hall sender is more likely to fail when warm!
i've checked & cleaned everything, so i ordered a new hall sender of eurocarparts for ?30 and im gonna fit it this weekend.
ill let you know how i get on.
Craig
Blue MK2
« Reply #18 on: 06 November 2003, 16:17 »
Is the engine timing right? fuel/Air mixture correct? Theres some Ht leads on ebay worth a try?
Offline Lee
« Reply #19 on: 07 November 2003, 18:48 »
Ok gambit let me know how it goes. Also im not sure how to check the timing my mate did the cambelt not that long ago and he lined up all the timing marks on the pulleys.
