Author Topic: "Italian Tune Up" is it required for TFSI engines ?  (Read 13836 times)
Offline Tornado8
Re: "Italian Tune Up" is it required for TFSI engines ?
« Reply #10 on: 22 March 2018, 21:31 »
In less technical terms (in the words of Basil Fawlty) I find a "Damm good thrashing" does it good every so often :grin:
Old, but a serial modder!
Offline Splashalot
« Reply #11 on: 23 March 2018, 00:39 »
Great info, Gnasher.  To clarify:
"Like some Toyota engines, this Audi powerplant family uses both direct and port injection. Direct injection is used to stabilize the idle and in full-load situations, while the port injectors are put to work under partial loads, where Audi engineers say port injection is better at mixing the fuel and air, with less soot produced and reduced CO2 emissions compared to direct injection. Unlike the Toyota setup, this engine operates either as a port-injected engine or a direct-injected one, and never uses both injectors simultaneously."
Reference: https://blog.caranddriver.com/audi-gives-us-the-skinny-on-its-third-gen-ea888-turbo-four-and-the-sq5s-twin-turbo-diesel-v6/
Sounds like once warm, the EA888 runs on MPI injection solely, except under heavy load.  So for most people that spells an end to the carbon build up issues of past.
1972 Turquoise Superbug S; 1978 Miami Blue Golf GLS; 2007 Mk5 Tornado Red Golf GTI; 2017 Golf 7.5 Trendline Tungsten Silver 1.4ltr 110TSi with DAP; 2018 Tornado Red GTI with DAP.  All MT.  Current: 2021 Mini Cooper SE, British racing green.
