Author Topic: Dealer fix for Soundaktor vibration/rattle?  (Read 25952 times)
Offline Nicks11
Re: Dealer fix for Soundaktor vibration/rattle?
« Reply #20 on: 30 March 2018, 10:44 »
Done this mod today following the vwroc guide and it seems to have worked a charm, rattle gone. Only prob, I forgot to mark the position of the wipers and not sure I've put the passenger one back in the right place. Should it cover the vin or sit above it?
Offline Watts
« Reply #21 on: 30 March 2018, 16:06 »
Hope that's clear enough, it was peeing down so difficult to photograph :smiley:
Previously:
Offline Nicks11
« Reply #22 on: 30 March 2018, 17:29 »
Thanks for that. The one on the instructions is in a slightly different place so I guess they might all be different.
Offline Jdm owner
« Reply #23 on: 01 April 2018, 23:32 »
This was the first thing I did unplugged the sh!tty speaker  :whistle:
Offline davyk31
« Reply #24 on: 02 April 2018, 08:49 »
Is unplugging an easy job, would like to try it without the noise as I reckon it makes the car sound like a diesel.
Mk 7.5 GTi Indium Grey with 19" Brescias
Offline mcmaddy
« Reply #25 on: 02 April 2018, 12:23 »
Turn it off with vcds or obd11.
Offline davyk31
« Reply #26 on: 02 April 2018, 19:21 »
Turning it off sounds a good option but I don't have either of those systems. Are they expensive?
Offline BlinGTIes
« Reply #27 on: 02 April 2018, 22:47 »
I’ve turned mine off through the car mode ‘individual’ settings. Set everything else the way you want I.e. so it’s mstly sport and turn the sound to ‘normal’. Works fine for me now.
Offline mcmaddy
« Reply #28 on: 02 April 2018, 23:24 »
Not sure where you are but plenty of members on here will do it for you.
Offline davyk31
« Reply #29 on: 03 April 2018, 15:08 »
I’m in Northern Ireland.
