Author Topic: Perhaps a new GTI and question on Discover Nav Pro vs Discover Navigation  (Read 22371 times)
Offline mcmaddy
Manual says it will run on 95 Ron fine but I've always used Shell v power in mine not because I think it'll give any more performance but because of the cleaning additives. VW Driver mag always recommend using the premium fuels on turbo charged cars.
Offline Guzzle
Great - it was a feature that was quite frustrating on my current and previous GTD's. The steering wheel is crammed with buttons, and you can do most things on it, but you couldn't change the media source. Great to hear you now can.
I just need to find a quick way of getting to the top of the menu (which is where the back button is to see all sources). If I'm listening to music from the SD card and want to go to a different source it seems like I have to scroll through the alphabet to get to the back button (is that right Vwjap?). I guess in that case, I would probably go back to the main screen...
As far as I know that is correct. I got bored of scrolling through the tracks on my ipod to switch the source to radio. Gave up and just reached across to tap the radio button on the MIB instead. Probably saves about 5 minutes each time.
7.5 GTD
Offline Vwjap
Ok so it does stay on the track list the second time (unless it’s a time thing, although I don’t change sources often) but one thing I did notice if you press ok on the track list it pauses the song
