Author Topic: VAG automatics  (Read 7584 times)
Offline Booth11
Re: VAG automatics
« Reply #20 on: 16 February 2018, 21:35 »
eg 'pedal box'?   :shocked:
A device that fits between the ECU and the throttle pedal which sharpens the response of the throttle pedal and removes  the laggy initial response.
https://www.diesel-performance.co.uk/products-overview/?key=DTUK+Pedal+Box+Plus
Older version than the current, but this is how it attached
http://www.golfgtiforum.co.uk/index.php?topic=276517.0
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline itavaltalainen
Re: VAG automatics
« Reply #21 on: 23 February 2018, 12:45 »
In manual mode box doesn’t shift up anyway, it just hits limiter.
In which car does that happen? Because in the Clubsport (and I believe in every other GTI) it's limiter and up-shift no matter which mode you're on.
Mk7 GTD MY17
That's super weird. Why would they implement a "change at the limiter" function on performance variants like GTIs and other petrols but leave it hit the limiter and stay in the same gear on a diesel?  :huh:   You're absolutely sure it doesn't up-shift? Would love to see a video of this.
It does change up even in manual mode, but only after sitting at max revs for a second or so..... I just manually shifted up long before then :D
