Author Topic: Overheating Issues!  (Read 6364 times)
Offline Imjustsid
Overheating Issues!
« on: 22 January 2018, 21:05 »
My GTI started to overheat out of no where.
My car was parked up over the xmas period for 5 week or so, i decided to take it for a drive and noticed that coolant temperature started to move pass the 90c mark, i didn't think much of it until it went all the way up to 130c and into the red, i managed to get the car home, and decided up open up the bonnet to see anything looked out of the ordinary and checked the coolant level, everything looked fine and the coolant level was spot on. Since owning the car i never had any issues with coolant levels its always been spot on.
I turn the car on next day and the engine management light came on and didn't turn off, also i noticed that the coolant gauge was moving up fairly quickly it was at 60c within a minute or so, i took it for a quick spin and again the coolant was increasing pass 90c so to be on the safe side i parked it up.
I got one of my friends to bring over his VCDS diagnosis kit and these errors were flagged up:
2 Faults Found:
16464 - Insufficient Engine Cooling / Coolant Flow
          P00B7 00 [047] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 83965 km
                    Date: 2018.01.16
                    Time: 22:29:44
15470 - Insufficient Engine Cooling / Coolant Flow
          P00B7 00 [175] - -
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 83965 km
                    Date: 2018.01.16
                    Time: 22:38:41
Readiness: 1110 0001
Not sure if anyone else has experienced these fault codes before? or experienced over heating like this?
I was hoping it was something trivial like a temp sensor!
The car is on 13 plate with 52k on the clock, not sure if this generation suffered the dodgy water pumps like the MK6
Offline fredgroves
Re: Overheating Issues!
« Reply #1 on: 22 January 2018, 22:22 »
Yes plastic impeller on the water pump... Had two colleagues 14 plate gtd's fail like this, under 60k on the clock too. That would be my guess as to what is wrong.
Offline Gulfstream11
« Reply #2 on: 23 January 2018, 08:10 »
That's pretty nasty. I know this forum rocks for knowledge regarding issues but the first port of call for me would have been dealer/indie for a fix. Hope you get it sorted.
Previous rides..MKIV 1.8T   MKIV PD150  MK5 GTI MK5 edition30 now MK7 GTI PP
Offline naxcars
« Reply #3 on: 23 January 2018, 16:12 »
Is there an uprated metal impeller pump for the car now?
2014 Golf GTI Performance Pack: Nav & Rear Parking Camera, DTUK FRS+
Offline fredgroves
« Reply #4 on: 23 January 2018, 16:13 »
Apparently not, or at least 18 months ago there wasn't.
Offline mcmaddy
« Reply #5 on: 23 January 2018, 17:00 »
Yes they are supposed to fit replacement ones that have metal impellers. Takes you back to MK4 days this  :whistle:
Offline barrym381
« Reply #6 on: 23 January 2018, 19:15 »
Don't fit a pump with metal impeller  :smiley:
