Author Topic: MK7.5 Stop/Start System  (Read 15383 times)
Offline Vwjap
Re: MK7.5 Stop/Start System
« Reply #10 on: 18 January 2018, 22:34 »
Depends, you need a android, the dongle, software is free unless you go pro, but if you want to use the apps you have to buy credits
Offline brettblade
« Reply #11 on: 19 January 2018, 10:03 »
I find it works great on the manual, granted the extra pedal makes it a bit clearer what your intentions are!
Orded 04/06/2016
Build W/C 01/08/2016
Handover 01/09/2016
GTI PP, CSG, Tech pack, parking pack, 90% tints, DCC, 19" Santiago alloys
Soon to be gone!
7.5R Indium Grey, 19” Spielbergs expected 01/03/2019.
Offline deltarikk
« Reply #12 on: 19 January 2018, 21:21 »
Obdeleven long coding:
Disable stop/start
1) Select Control unit 19
2) Select Adaptation
3) Select Stop start limit voltage
4) Change value to 12 (default is 7.6)
5) Press the green tick to confirm
On some earlier cars the above method doesn’t work.  For these, there is another method where you change the coolant temp to something it will never achieve.
Thanks for that Rebecca, very kind, I think I'll give it a go and order unit  :wink:
Offline Booth11
« Reply #13 on: 19 January 2018, 22:21 »
Disable stop/start
Anytime.  It’s well worth (the Pro version) the money, even if you have to buy a cheap Android device.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
