Author Topic: MK7 changes  (Read 11628 times)
Offline mcmaddy
Re: MK7 changes
« Reply #20 on: 16 January 2018, 18:02 »
I doubt it's that different to be honest Fred. It's probably only an updated screen.
Offline fredgroves
Re: MK7 changes
« Reply #21 on: 16 January 2018, 19:18 »
Driving a much higher resolution screen. The 7.5 standard nav is basically the old nav pro hardware and that can't run dual map outputs due to processing limitations
Offline mcmaddy
Re: MK7 changes
« Reply #22 on: 16 January 2018, 22:48 »
TFT screen appears to be the only difference that I can find. Resolution is the same but then again two different sites quoted two different specs  :grin:
Offline fredgroves
Re: MK7 changes
« Reply #23 on: 17 January 2018, 09:20 »
Resolution definitely isn't the same - the new NavPro is widescreen!
Its 1280 x 640 compared to the previous 8" 800 x 480.
In terms of desktop computers, the difference in powering that is nothing, but the computer in your car is not a desktop PC running the latest top end Intel processor, its the smallest processor that they can get away with.
When you have the map on the AID, you can have a different view to the one on the MIB as well - so it is actually generating twice the output too.
Its really hard to find the actual manufacturer of the MIB unit and read their tech specs sadly.
Offline mcmaddy
Re: MK7 changes
« Reply #24 on: 17 January 2018, 09:34 »
Most VW units were made by continental but not sure on these newer ones. Just found a page that confirms your specs Fred on the screen. I'd still be amazed if the actual brain in the glovebox has changed much.
Offline fredgroves
Re: MK7 changes
« Reply #25 on: 17 January 2018, 09:39 »
I forgot that the actual unit is in the glovebox.
I guess the simple way of determining if they are different then is to see if the VW part number is different... I've no idea how to do that mind you.
Offline Jeni_R_
Re: MK7 changes
« Reply #26 on: 17 January 2018, 11:38 »
So it sounds like if you have mib2 you can retro fit the newer display.
Super off to see what its gonna sting me to get this done thanks guys :)
