Author Topic: 17” wheels on PP/R/CS  (Read 4920 times)
Offline mkviken
« on: 14 January 2018, 13:47 »
Just got some 17” Audi TT wheels for my CSS over the colder months
They are a bloody tight fit - just about see daylight between the calliper and wheel
So tight in fact I’m having to get them rebalanced as the weights won’t clear the brakes
Anyone else tried 17s on their R or PP gti etc?
We’re your brakes very close also?
« Last Edit: 14 January 2018, 21:56 by mkviken »
Golf GTI 7.5 230 white silver
Offline Wide
Re: 17” wheels on PP/R/CS
« Reply #1 on: 14 January 2018, 14:11 »
I have 17" now, it is crazy tight but works!. See below!.. :whistle:
https://youtu.be/gjn-Q0pbTts
My Youtube Channel ** MK8 R and MK7.5 GTI PP**
https://www.youtube.com/channel/UCOQb17Kro9L-iuT91cKxsjA
And My INSTAGRAM FaceliftGT
https://www.instagram.com/p/CHKNpaNHog_/
Offline mkviken
« Reply #2 on: 14 January 2018, 14:43 »
Thanks
When you say tight how tight do you mean?
I’m talking literally the width of a credit card between calliper and wheel
Taking the wheels back in to get the weights moved as far out to the rim as possible...
Offline 2007GTI
« Reply #3 on: 14 January 2018, 14:59 »
This has come up before, in some countries 17" wheels are still standard on Mk7 GTIs, so it's perfectly normal, if a little tight, depending on wheel design of course.
Offline Eccie
  • Keyless & Penniless
« Reply #4 on: 14 January 2018, 15:27 »
I run 17” wheels in the winter on my PP, they fit ok but are quite snug, didn’t need to move the wheel weights
Offline Wide
« Reply #5 on: 14 January 2018, 16:22 »
Thanks
Think it is about 5mm to the weights...so no problem.. :whistle: :grin:
Offline mkviken
« Reply #6 on: 14 January 2018, 18:12 »
Well mine are damn close. Had the weights moved and they miss th fronts there’s maybe 1mm clearance
Rears are close too which I didn’t expect
The calliper actually sits inside the wheel as if they are shaped around each other. Barely any clearance.
One of the weights is just say touching the calliper so I’m going to mark it’s position and move it out a few Mm and stick it down again
They’re from an 08 Audi TT so would expect them to fit fine
« Last Edit: 14 January 2018, 18:29 by mkviken »
Offline Wide
« Reply #7 on: 14 January 2018, 19:30 »
WTF??!?! :grin:, that was close  :laugh:
Mine are not at all thaat close... :smiley:
Offline mkviken
« Reply #8 on: 14 January 2018, 20:36 »
marked the position of the weight and removed it and re stuck it a couple of mm further outboard and it misses the rear calliper now. what a faff!
Offline Mikea
« Reply #9 on: 26 January 2018, 22:51 »
Out of interest what model of Audi alloy are you using or even just the offset?
« Last Edit: 26 January 2018, 22:54 by Mikea »
Sold 2021 : 2016 5dr GTi Clubsport Edition 40 DSG - No. 403
Tornado Red, Dynamic Chassis Control, Rear View Camera and 19" Brescia Alloys
Up! Gti Red 5 door, park and cruise, city emergency pack, climate control and 5 year warranty
