Author Topic: OBD eleven post ....sorry  (Read 17441 times)
Offline Vwjap
Re: OBD eleven post ....sorry
« Reply #20 on: 13 January 2018, 16:37 »
« Last Edit: 13 January 2018, 16:40 by Vwjap »
Offline Jeni_R_
« Reply #21 on: 13 January 2018, 16:51 »
Ooooh it worked ! FAB thanks
Now someone tell me acoustic noise lock/unlock what shud this be i assumed a bleep but selected it and it doesnt appear to make any noise ?
Not done it myself but don’t you have to set it in the MIB, plus I think you might have to reset the MIB (press and hold on/off for 10 seconds) for it to appear
MIB ?
Offline Jeni_R_
« Reply #22 on: 13 January 2018, 16:57 »
Offline Vwjap
« Reply #23 on: 13 January 2018, 16:57 »
Stereo system in oldskool ;-)
Plus I think you have to have the factory fitted alarm
Also it depends what mk7 you have (check your car is the correct one in the app), as a later one has different codings so some apps may not work because they can’t find all the codings they need to change, but they are updating all the time
Offline itavaltalainen
« Reply #24 on: 13 January 2018, 17:26 »
You need to change the following things in BCM (module 09):
Address 09   5Q0 937 084 CL   channel IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global   adapted from   not active    to   active
Address 09   5Q0 937 084 CL   channel IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln   adapted from   not active    to   active
Address 09   5Q0 937 084 CL   channel IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung   adapted from   not active    to   active
Address 09   5Q0 937 084 CL   channel IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln   adapted from   not active    to   active
Then acitvate in settings in the MIB (in section locking/unlocking) then it should work.
Offline Booth11
« Reply #25 on: 13 January 2018, 17:38 »
Jeni doesn’t have pro obdeleven so can’t long code.........yet.  :wink:
It’s a chirp rather than a bleep but you can’t miss it, quite audible once activated.!
« Last Edit: 13 January 2018, 17:41 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Vwjap
« Reply #26 on: 13 January 2018, 17:38 »
She hasn’t got pro dude,
« Reply #27 on: 13 January 2018, 17:46 »
Only said what needs to be done (or rather posted a change log from my VCDS debug file).
I have only used OBD Eleven once or twice as pro version and was very underwhelmed by it.
Offline Jeni_R_
« Reply #28 on: 13 January 2018, 18:12 »
Shes off to get pro if she needs it for this mad batsh*t coding 😁😁
Twll me use the phond or ipad whats easier
Offline Vwjap
« Reply #29 on: 13 January 2018, 18:14 »
See that’s why I asked what age her car was, because it’s under feedback signals on earlier cars,
