Author Topic: *Long Term Review* Facelift PP. Who knows if you can restrict tailgate??!  (Read 9241 times)
Offline Wide
Who knows if you have a restriction opening on the tailgate ?. My facelifted car actually opens the tailgate higher than before.
Which means it takes in the garage door, and can give scratches I have noticed .. :angry:
Anyone handy here ?!  :whistle:
audi had a similar problem on the Q3  it was going so high some peo0le couldn’t reach it
so they  did a shorter  support strut. To limit the opening height , my dealer swapped them for free
Maybe  VW do a similar thing  .?????
Interesting!  :smiley:
My Youtube Channel ** MK8 R and MK7.5 GTI PP**
https://www.youtube.com/channel/UCOQb17Kro9L-iuT91cKxsjA
And My INSTAGRAM FaceliftGT
https://www.instagram.com/p/CHKNpaNHog_/
Offline Wide
Just tested in our double garage with separate single doors MK7 GTI & MK7.5 R they are identical raise and struts both are 12cm of garage doors tailgates fully open.
That is strange?. My MK7 GT don´t open so high. But can´t understand the different in tailgate. I will try to measure more.. :smiley:
Offline Wide
I'm not aware of any way to lessen the amount the tailgate opens. Could you not add some foam to where it catches your garage door? Or reverse in instead of drive in?
I use foam on the garage door, but when the car is dirty. The tailgate is so strong that it slide a little on the foam and makes scratches.. :angry:
And no the garage is so tight so if i reverse i can´t get the stuff in the boot.. :grin:
I don’t open the tailgate in my garage for this reason - always wait until the car is out of the garage before putting things in or taking them out of the boot. Not always as convienient as it would be to do it in the garage, but IMO, better than scratching up the tailgate where it would touch the garage door.
Yes you are right will not open the tailgate anymore in the garage, to i find a solution of the problem.. :grin:
Offline 2007GTI
you could just buy new struts which don't open as high.
Offline Wide
Yes maybe on one side only?   :smiley:
Offline dubber36
Slam it on air bruv. Problem solved.
Offline Wide
 :grin: :grin:Yes that would be the easiest  :grin:
But it strange that it open so high, the GTI is lower than my other mk7 GT... :sad:
