Author Topic: GTI 7.5 Map Update....  (Read 52502 times)
Offline seanng
Re: GTI 7.5 Map Update....
« Reply #70 on: 10 January 2018, 14:05 »
Can you only select the UK map to copy over? I do not need the other Europe maps, so that could reduce the size dramatically!
Offline scanesare
  • GTI Clubsport
« Reply #71 on: 10 January 2018, 14:26 »
Lets put it this way, when I removed the MIB2 from it when I had a MIB1 NavPro on my last car.... it worked just fine.
I wonder if the size difference is simply that the MIB2 system supports compressed maps? There is quite a difference between MIB2 and MIB1 in many respects... more than meets the eye, which is why you could never update a MIB1 device to support App Connect etc.
But that sounds a bit different no? MIB1 surely doesn't need MIB2 data as it's not forwards compatible. MIB2 though could potentially use some MIB1 data on top of its own MIB2-specific data. In that case only copying the MIB2 folder would not work. But I'd expect to just come across a failure.
Offline fredgroves
« Reply #72 on: 10 January 2018, 14:39 »
I think you'd have to manually edit the manifest file to remove the others, otherwise it would try to find them and fail...
Offline scanesare
  • GTI Clubsport
« Reply #73 on: 10 January 2018, 19:27 »
So... just the MIB2 folder and .md5 file failed to be recognized as a valid source for upgrading. I guess all units need MIB1 data as well so I'll be adding that to the SD tomorrow and re-try. Sounded too good to be true...
Offline fredgroves
« Reply #74 on: 10 January 2018, 19:28 »
Hmm that's odd
Offline scanesare
  • GTI Clubsport
« Reply #75 on: 10 January 2018, 19:51 »
Hmm that's odd
I'll report if just copying the MIB1 folder extra did it or there was another issue.
Offline mcmaddy
« Reply #76 on: 11 January 2018, 06:50 »
Both 1 and 2s use the same map data but it just displays it better on the mib2. I would guess the mib2 file contents contains only data that the 2 can use and removing it for a 1 would work like Fred did. Unfortunately for a mib2 pro unit we need the full download.
Offline scanesare
  • GTI Clubsport
« Reply #77 on: 12 January 2018, 10:43 »
You can't use a USB key, it has to be a SD card - it will only look for updates in the SD slots.
Yes, you can strip the MIB2 folder out, but keep the file in the root directory (if you look there are 2 folders and a file, the file is the bit you need to keep)
Turns out you can actually use a USB key just fine. The soft button is labelled "Update USB/SD" and so I tried with a USB flash this morning and it starts updating normally. (Strangely, on my first attempt with an SD yesterday it seemed to work fine, then when it reached 100% an error popped up: "Error: Restart the software update"  :huh:  Let's see if I succeed with the USB this time.
Also, as said before you can't strip any folder for MIB2 units or it fails, it needs all the contents of the zip file.
Offline fredgroves
« Reply #78 on: 12 January 2018, 10:53 »
I guess its changed a bit since MIB1.
I've not actually managed to get my MIB2 NavPro to update since I've had this Mk7.5...
Kinda given up as I rarely use the VW nav itself now.
Offline seanng
« Reply #79 on: 12 January 2018, 11:02 »
Adding speed cam POIs and using car net to update traffic has reinvigorated the VW sat nav for me
