Author Topic: Ambient Lights - wiring  (Read 18804 times)
Offline Jeni_R_
« on: 03 November 2017, 10:11 »
Would anyone be so kind in telling me where i access the wiring for the interior ambient lights so i can swap the ends round to make them red as per previous post couple years back Cebbes (no longer active) did this and it worked but i am unsure where to access the wiring i have manage to source the Haynes Manual for my car but its like reading swaheely and i cant find a direct link on it to the wiring
Anyone know where i should be looking ?
TIA
Offline I wanted a GTi
Re: Ambient Lights - wiring
« Reply #1 on: 03 November 2017, 11:12 »
Not sure but pretty sure that you would have to remove the door cards.
Offline Jeni_R_
« Reply #2 on: 03 November 2017, 11:14 »
great thanks i just needed to know that was the case thanks
Offline Jeni_R_
« Reply #3 on: 05 November 2017, 11:50 »
Got doot card off but fkd if i know what cables to swap around theres 3 blue brown and a white goes into the ambient light socket not got a scooby so stuck it bak on again
Bollox  :sad:
« Reply #4 on: 05 November 2017, 12:43 »
Bollox  :sad:
Brown and white I reckon.
Offline Jeni_R_
« Reply #5 on: 05 November 2017, 17:05 »
Bollox  :sad:
How do u remove the wires ? Do they pop out ?
« Reply #6 on: 06 November 2017, 10:28 »
Bollox  :sad:
I haven't got a clue but I would think if they don't disconnect easily then I'd just cut them and strip back and swap them over.
Offline Jeni_R_
« Reply #7 on: 06 November 2017, 11:09 »
Bollox  :sad:
OK so NOWHERE shows what colpours to swap nor tells me what colour is what i gather
BROWN = LOAD
Blue = NEUTRAL
So what the hell is the white one ?
Offline GTD1414
« Reply #8 on: 06 November 2017, 12:00 »
Can you post any pics of the wiring/pins?
From Cebbes post: Ambient lighting in Doors are led, so this has two connection pin 1 and pin 2.
So when you switch the kabel with pin 1 to pin 2 and pin 2 to pin 1 you will get red lights. yust reverse
Offline Jeni_R_
« Reply #9 on: 06 November 2017, 12:10 »
Below is the thread for someone fitting the emergency door light it shows the connections
http://www.golfmk7.com/forums/showthread.php?t=13887
« Last Edit: 06 November 2017, 12:13 by Jeni_R_ »
