Author Topic: Movie: First Winter Drive in the Facelift GTI, fun :)  (Read 9709 times)
Offline Wide
Those winter wheels would look great with some spacers added...  :whistle:
 :grin: :grin: Yes they look awfull in the back... How much spacer can you put on these stock rims?!.. :sad:
My Youtube Channel ** MK8 R and MK7.5 GTI PP**
https://www.youtube.com/channel/UCOQb17Kro9L-iuT91cKxsjA
And My INSTAGRAM FaceliftGT
https://www.instagram.com/p/CHKNpaNHog_/
7J wheels on a mk7 can take some big spacers!
If you're going to drive in snow then you'll still want plenty of clearance so I'd play safe and go 12mm front and 16mm rear but you'd easily take 20mm rear spacers (each side).
Offline I wanted a GTi
I have 20mm each side on the back of mine.
^^^^ And they square the car off nicely  :cool:
Offline Wide
Ok, so much?!..  :smiley:. I will look at that!  :smiley:
Offline Wide
 :smiley: That looks realy great!  :smiley:. You need new bolts for the wheels also?..
No the spacers are bolt on so you bolt the spacer to the hub and then your wheel bolts to the spacer.
Offline Wide
Like this? :). Is this the best solution?.
https://www.scstyling.com/bilmodeller/audi/a3/spacers-15mm-audivwseatskoda
I like H&R or Sparco myself.
Offline Wide
Re: Movie: First Winter Drive in the Facelift GTI, fun :)
« Reply #19 on: 11 December 2017, 21:12 »
The First snow in Sweden  :smiley:
https://youtu.be/aeqFQWRZ2sU
« Last Edit: 11 December 2017, 21:17 by Wide »
