Author Topic: Are the Mk7.5 Headlights Different If you Spec Dynamic Light Assist ?  (Read 39680 times)
Offline Vwjap
I wonder if it's to do with LED headlight bulbs, in the fact that LED bulbs are more that 2000 lumens and then shine into the mirrors of the headlight to make the pattern, whereas do LED headlights actually shine into a mirror pattern to make the beam or do they just shine forward so dirt on the glass would not change the pattern to make glare
« Last Edit: 12 October 2017, 13:49 by Vwjap »
Offline I wanted a GTi
My Polo GTI has LED headlamps and headlamp washers, and I don’t have the winter pack. Like the mk7.5 Golf, the all new Polo when fitted with LED headlamps doesn’t have headlamp washers, unless it has the winter pack fitted. So, I’ve concluded that;
  • either the regulations that Diaz Auto refers to have changed so washers are no longer a requirement
or
  • as Fred has suggested, the current LED headlamp bulbs used by VW have a lumens rating of less than 2000.
I can’t get too excited about whether or not headlamp washers are fitted; my preference would be that they’re not, as IMO washer spray without wipers isn’t that effective at cleaning, and I find the spray up the bonnet and over the wings really annoying, especially when I’ve just cleaned my car!
Cars back in 2014 with led lights didn't need washers either.
Offline jv
  • Administrator
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Vwjap
Happy days https://www.youtube.com/watch?v=8EOjgd67u0M
I used to get my friends to sit in my old 325i sport and use the washers so I could look at https://youtu.be/lJQd1QLkPAk
It was quite rare back in the early 90's and I loved them.
Offline Daz Auto
  • Other brands of washing powder are available.
10/8/2017 - GTI Performance, Red,5dr DS
Offline Watts
I never realised there was so much to consider with headlights, important of course, but not perhaps the most obvious choice for  such a long and in-depth discussion :wink:
Previously:
Offline andy28
A couple of linked questions if I may...
I've noticed that the headlights on my 7.5 (no Dynamic Light Assist, so only outer beam working) are pretty poor on country roads. I never had to rely on full beam as much with my previous VW CC with Xenons, but now regret not choosing DLA on my GTI. I've got it booked in to check the range (it's not a quick under the bonnet adjustment with LEDs unfortunately) but get the feeling I'm going to be told the range is fine or it's because I'm slightly lowered (Eibach pro springs). Anyone else without DLA noticed anything at all?
So I was flicking through the light selector switch and there doesn't seem to be any difference from the front between "side lights" selected and "off" (both just run the front DRLs). Is that right? I was expecting there to actually be side lights  :grin:
GTI Clubsport Edition 40
#301 and then #190
Offline hog_hedge
It definitely is a quick under the bonnet adjustment with LEDs. Have a look on your headlights, you can raise and lower them using one of alan’s keys (though I forget which one).
If it’s any consolation I had to raise my dipped beam on my 7.5 a week after I took delivery because the range was dangerous, good job they checked them on the PDI :whistle:
Offline BobbyT
Can you alter the range via VCDS or do you just do it by turning the screw on the unit?
