Author Topic: OBDeleven question  (Read 22189 times)
Offline I wanted a GTi
Re: OBDeleven question
« Reply #20 on: 02 October 2017, 20:31 »
What are they there for then in pro version? Guided functions?
(No full quote needed btw)
Have you ever read anything about OBDeleven or are you just assuming stuff again? You seem to know so much about it :rolleyes:
Offline Vwjap
« Reply #21 on: 02 October 2017, 20:31 »
I think you'll find there there in the standard version, the pro upgrade adds the coding, no point in removing stuff
Offline itavaltalainen
« Reply #22 on: 03 October 2017, 15:22 »
I wasn't saying functionality should be removed, just that I don't understand why you'd have to spend imaginary credits for anything if you have the pro version (and before someone who wanted a GTI says again you don't need to use credits why does the website say you need credits even if using certain things in pro version).
Offline Vwjap
« Reply #23 on: 03 October 2017, 15:58 »
Because VIM and MIM is not available any other way 😉
Offline Finglonga
« Reply #24 on: 03 October 2017, 16:39 »
Standard version......You can only code using Apps and the Apps need credits to use.
Pro Version..... As the above with the standard but it has unlocked functionality and now you can use long coding and adaptations and unlike with using the App's it is totally free.
Offline Booth11
« Reply #25 on: 03 October 2017, 18:38 »
If you've got the Pro, why not use the long coding rather than the apps. That way you know exactly what you've changed and have a log of it. Surely the reason for getting the pro version?
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline monsta
« Reply #26 on: 03 October 2017, 20:58 »
You can adjust the sound with adaptation instead of long coding - scroll to the bottom control unit option, choose adaptation hit the only option on there and set a new percentage.
I'm always fiddling with mine, had it on zero for ages and then I miss it every now and then so re enable it!
https://www.youtube.com/watch?v=2mzzKIEGkMo
Offline 2007GTI
« Reply #27 on: 03 October 2017, 21:55 »
thanks for that!
« Reply #28 on: 04 October 2017, 08:02 »
If you aren't very experienced and bought pro I think it'd be nice to still be able to use the automated functions to code something (without needing credits).
OBD11, even in pro version, is aimed more at the occasional user who often would not necessarily have the experience would have, excluding a few users on here.
Offline 2007GTI
« Reply #29 on: 05 October 2017, 12:12 »
So I tried to turn off the start stop in my mums 2015 Polo, used adaptions, turned it to not active and it said change accepted, then a warning message came up on dash, and the bloody thing is not turned off! Did it twice, exactly the same!
Any ideas?
