Author Topic: Fuse Taps  (Read 3315 times)
Offline mcmaddy
Fuse Taps
« on: 06 September 2017, 11:32 »
Anyone know what size fuse taps are needed to fit a dash cam? Are they standard size fuses?
Offline Vwjap
Re: Fuse Taps
« Reply #1 on: 06 September 2017, 13:45 »
You have both standard and mini size fuses in the fuse box (although I don't remember which one I tapped into) if your Hertfordshire way you can pop over and pick up one if it helps (my bad, see your in mackem country)
« Last Edit: 06 September 2017, 13:46 by Vwjap »
Offline Finglonga
Re: Fuse Taps
« Reply #2 on: 06 September 2017, 16:09 »
Standard large ones....pennies of Fleabay. :wink:
Offline mcmaddy
Re: Fuse Taps
« Reply #3 on: 06 September 2017, 16:32 »
Excellent cheers
Offline I wanted a GTi
Re: Fuse Taps
« Reply #4 on: 06 September 2017, 16:55 »
Which one did you get?
Offline mcmaddy
Re: Fuse Taps
« Reply #5 on: 06 September 2017, 19:25 »
Thinkware F770
Offline Finglonga
Re: Fuse Taps
« Reply #6 on: 08 September 2017, 09:04 »
Good choice, really pleased with mine and zero issues.
Offline mcmaddy
Re: Fuse Taps
« Reply #7 on: 08 September 2017, 13:19 »
Which fuses did you tap into Finglonga?
