Author Topic: Video: *Tire Problem* On the Facelift GTI...now set number 6 in one year :)  (Read 13201 times)
Offline Watts
Re: Video: *Tire Problem* On the Facelift GTI.. :)
« Reply #20 on: 27 August 2017, 14:59 »
My experience suggests that while the contis might perform best, they last only about two thirds of the distance vs Michelins. Personally I can't afford that.
On the other hand, essentially pretty much anything wins over the OEM BS's except on wear, where the damned things are crap forever.
I was wondering about life, my P-Zeros have just gone over 18k with a bit more life in them, on last check they were at 3.5 and 4.5mm so will change them before winter. If I can get the same again from Michelins then they might be worth the extra £120 a set with the additional benefits of performance and comfort. I'd be disappointed if I only got 12k from a set of tyres, especially at £600 :rolleyes:
Previously:
Offline Wide
« Reply #21 on: 27 August 2017, 19:09 »
Can't comment on PS4, but PS4S are very noticeably quieter than Conti 5Ps so if Conti 6 are the same as 5Ps in the noise stakes, then they will be noisier than PS4S.
I had Conti 5 on my Mk7, and think the Conti 6 is quiter.
But as i said, maybe the PS4S is better.. :huh:. I buy them next time if it´s the way.. :grin:
If the Conti 6's are quieter then they'll likely be on a par noise wise with the PS4S.  :smiley:
Think all the tires in this size are noisy  :grin:. But you are satisfied with the performace of the PS4S?.. :smiley:
Wide, yes, to degree 19's can be noisy but some are moreso than others. Same with the hardness of the ride.
I've only had the PS4S on since Friday but have done a fair few miles now on varying roads to test them out, and they are so far proving to be superior to the Conti 5Ps on all levels, and that's saying something because I rate 5Ps highly.  The PS4S are  - quieter, less harsh and more comfortable ride even with DCC in Sport, better at absorbing rough/potholed roads, better grip, exemplary braking.  They've yet to be driven in the wet and it will be exciting to see how they fare through winter (do not use winter tyres in my location).  More extensive thoughts on the PS4S (so far) in my thread here.
http://www.golfgtiforum.co.uk/index.php?topic=275792.msg2572744#msg2572744
Tramping, as discussed above is not an issue on the 4WD  R, as is more prevalent on front wheel drive cars and a poor tyre can really exacerbate the issue.
I know a few with Conti 6 on their R's and they are very pleased with them.  :smiley:
I have Conti 5 on the Mk7, and i agree with your comments. But i think the tires will last long. Have done 40 000km and they can do many more miles.. :smiley:
But think the Conti 6 is on another level  :wink:
I have 2 people that have new R here in Sweden, they both have problem with Tramping on them. So they have changed the dogbone, and it is a new car according to them.. :grin:
My Youtube Channel ** MK8 R and MK7.5 GTI PP**
https://www.youtube.com/channel/UCOQb17Kro9L-iuT91cKxsjA
And My INSTAGRAM FaceliftGT
https://www.instagram.com/p/CHKNpaNHog_/
Offline Wide
« Reply #22 on: 27 August 2017, 19:19 »
Is it really true, according to my tire company. So, the PS4 has a lot of poorer durability with a little better grip. Much smoother rubber. But he may be wrong. :sad:
Offline Booth11
« Reply #23 on: 27 August 2017, 19:54 »
Glad you are liking the Conti 6. :smiley:   Do you run the Conti 5Ps just through the warmer months?  Presume winter tyres required in Sweden?  Tyre life will come down to a variety of factors.  I've known some get as little as 4K and 8k miles out of a set of fronts.  :shocked:
Interesting about the tramping on the R, first instances I've heard of.  What tyres were they running?
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Wide
« Reply #24 on: 27 August 2017, 20:10 »
Yes we have to use real wintertires in Sweden. I have these in 17" between Nov to Mars.. :angry:..
Pirelli P Zero on the Golf R...standard tire from factory.. :smiley:
Offline Wide
Yes this was not the plan to have tried 6 sets of wheels...  :whistle:
But hope i not need to change wheels this year..:rolleyes::D:D
https://youtu.be/6YJJ4xeb7mQ
Offline mcmaddy
Interesting watch 👍. I loved the continentals that came from the factory on my 2013 gtd but again a lot of people dismissed them. So it's either conti 6 or Michelin sport 4s come tyre change time.
Offline Wide
Thanks, yes i have some isues.  :grin:.
I Choice the Conti 6 because of the road noice on the 4s. They are similar in prize and performance ..
But next time i will try the 4S!  :grin:
Offline Tornado8
A word for the Falken Azenis Fk510https://www.youtube.com/watch?v=QseDx-aBaK4&t=498s Just fitted a set. Good value and good reviews. so far no complaints :smiley:
Old, but a serial modder!
Offline Jim_mk7.5
Just put these on mine...
Looking forward to bedding them in round Wales this weekend..  :smiley:
NOW - 330e M Sport
