Author Topic: DCC with 19" Alloys, is it worth it?  (Read 11093 times)
Offline JamesR27
« on: 28 July 2017, 08:34 »
Hi, It's getting to the 4 year mark with my car so looking at options to upgrade. Just wondering what the good people on here think about the ride quality on the 19" options.
This time I thinking after having 3 GTI's of getting an R with Pretoria's if that helps.
Mk 8.5 Clubsport Pure White, Queenstown, DCC.
MK 7.5 R Pure White, Pretoria Silver, DCC, Rear Camera.
Gone - MK 7 GTI Carbon Grey, Rear Camera, Service Pack.
Gone - MK 6 GTI  Reflex Silver, Monza Shadows, RCD 510, Rear Camera, Bluetooth, Tyre Pressure Sensor, Xenons Convenience pack, Service Pack :)
Gone - MK 5 GTI Reflex Silver, Monza II 18's, Luxury Pack, Mulitchanger
Offline fredgroves
Re: DCC with 19" Alloys, is it worth it?
« Reply #1 on: 28 July 2017, 09:02 »
Having just ditched DCC on my new GTD, I can't say I've felt the need to have it at all.
Sure I've only got 18's but the 19's ride harder full stop, even with DCC. I did test drive a GTD with 19's and no DCC originally and it was well, a bit different, but..
Because you can't really experience with and without very easily (unless your local dealers have demo R's that have that config), you'll never really know.
I'm not saying DCC is utterly pointless, I'm just saying that if it breaks the budget, dropping it won't be a disaster.
No performance Golf in OEM guise has a truly harsh ride, they simply are more refined than that.
Offline Wide
« Reply #2 on: 28 July 2017, 09:26 »
I think it´s a option you can´t miss.. :wink:. How much is it in UK?..
I have 19" and the ride in Comfort mode is Crazy smooth.. In my individual mode ia have everting in Sport, and the ride in Comfort. It great when yoy drive fast on bumpy country roads.. :grin:
My Youtube Channel ** MK8 R and MK7.5 GTI PP**
https://www.youtube.com/channel/UCOQb17Kro9L-iuT91cKxsjA
And My INSTAGRAM FaceliftGT
https://www.instagram.com/p/CHKNpaNHog_/
Offline fredgroves
« Reply #3 on: 28 July 2017, 09:54 »
900 quid...
Offline Watts
« Reply #4 on: 28 July 2017, 10:06 »
I haven't tried DCC but have no complaints with mine on 19s without. I'd be surprised if this thread will be of any use to your decision as you will get the full spectrum of possible answers. Bottom line is, do you want to spend the extra £900?
Previously:
Offline itavaltalainen
« Reply #5 on: 28 July 2017, 10:14 »
I notice not having DCC in cornering ability, if I drive it harshly.
Also it was much smoother on the concrete hell of M42 and M25 (used in comfort mode).
Offline mcmaddy
« Reply #6 on: 28 July 2017, 10:55 »
I test drove an R on Pretoria's before buying my gti and I felt it was an excellent ride without DCC. I think the extra weight of the 4wd system just makes the R feel more planted. I did however spec DCC on my pp gti and don't regret it as it just gives you a bit more choice.
Offline Sootchucker
« Reply #7 on: 28 July 2017, 11:11 »
Both my GTD's have had DCC (the first White one with 18"'s and the current Grey one with 19"'s).
TBH, I've never driven a MK7 therefore without DCC, but I was amazed when I got the White car how good is was in comfort mode. With the current car I was expecting to have to put it in comfort mode all the time, but much to my surprise, even in standard (or even sport" mode, the car is still very compliment, and doesn't feel a whole lot different to the 18"s. Yes there is a difference and yes it's a little harsher over the bumps, but not by much.
I'm glad I have it, but based upon trying it in all the various settings, I'm not 100% it really is needed (more a nice to have) :-)
« Reply #8 on: 28 July 2017, 13:03 »
I thought my R on 19's actually rode more smoothly than my GTI PP did and neither of those cars had DCC.
£900 up front is a fair few quid but spread over several years if you're taking finance is less painful in small chunks if you want to look at it that way.
Personally I'd not bother but there are those that say they couldn't live without it (which I find a bit odd unless they have a spectacularly bad back, in which case I'd think the G-forces of a performance car being used as it should/would outweigh suspension discomfort on many levels).
I've had quite a few GTI's over many years that have had suspension kits (I was young once) and never appreciated the harder ride of most kits yet put up with it for improved dynamics and looks (as the factory suspension in those days wasn't the car's strongest point), plus the cars were all bought used so had a few miles on them therefore I was just replacing worn components in some ways. Since the mk5 I've not found any need for a suspension kit as the factory suspension is very good.
it's always under appreciated that it's the springs that do more for the ride quality on British roads than the dampers. If the springs are stiff you get a crashy ride and if they're soft you get a bouncy ride. The standard springs are somewhere in the middle and the standard dampers are fine for normal road use iMO. If you intend to do trackdays then firmer damping is a must so I'd 100% spec DCC if that was the case.
Offline CHB100
« Reply #9 on: 28 July 2017, 15:18 »
Well on a standard GTI I would recommend it with or with either 18/19s
I had it on a Mk6 and now on the R and my wife's Mk7 doesn't have it.
Thing is the R rides incredibly well in whatever mode on 19"s. So yes I would opt again for the comfort mode especially on Motorways where there are no tight bends!, also on very bad surfaces. But mostly Normal is perfect. Also I intend keeping the car for sometime. So cost dissipates.
Up to you on a 19" R maybe (it drives well on 18"s too) on a 18/19" GTI for sure IMO
Arrived 15/5/17 Mk 7.5 R Lapiz 5dr DSG, Prets, Pan Roof, DCC, Rear View Cam.
Our other car is a Mk7 GTI DSG 5dr Tungsten, Vienna, Rear View Cam, Park assist.
