Author Topic: Mk7.5 GTI/ GTD - Mud Flaps  (Read 22204 times)
Offline davyk31
Re: Mk7.5 GTI/ GTD - Mud Flaps
« Reply #30 on: 09 September 2017, 19:51 »
How did you trim the rear flaps? Was it a file job or cutting?
Mk 7.5 GTi Indium Grey with 19" Brescias
Offline Fewie
« Reply #31 on: 09 September 2017, 20:58 »
@ Macleesh, I've just fitted mine to my GTI today. Same part numbers as you quoted.  The tears where a doddle but I can seem to get the plugs fitted on the fronts, the ones you drill from underneath and then push into place.  Did you have any issue? I'm wondering if I didn't drill deep enough?
MK7.5 Golf GTI in Isaac Blue with Performance Pack, 19" Brescia's, Dynaudio, Reversing Camera & Climate Screen, ordered 16/05/17.  Counting down the days to collection on September 2nd
Offline Macleesh
« Reply #32 on: 09 September 2017, 21:21 »
Stanley knife made short work of it. They are made of fairly soft rubbery plastic, very easy to slice bits off.
Sean
Offline Macleesh
« Reply #33 on: 09 September 2017, 21:26 »
I found just pushing them with my thumb didn't work. I used a screwdriver to push the head in and that seemed to make them snap into place just fine.
Sean
Offline davyk31
« Reply #34 on: 10 September 2017, 07:47 »
Sounds like there is drilling needed to fit, is that right? Usually all the holes are already there.
Offline Macleesh
« Reply #35 on: 10 September 2017, 08:43 »
You use the two existing screws that secure the wing liners but need to drill extra 8mm holes into wing liner or under body covers & rear balance to take plastic pop rivets.
No drilling of metalwork required.
Sean
Offline Mag_Pie
« Reply #36 on: 18 December 2017, 21:39 »
So the MK7 GTI mud flaps also fit the MK7.5 with the same part numbers etc?
Offline SRGTD
« Reply #37 on: 18 December 2017, 22:00 »
I think the rears need to be trimmed to make them fit; the attachment area (lower trailing edge of rear wheel arch / bumper) on the car is a different shape / profile on the mk7.5 compared to the mk7
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Mag_Pie
« Reply #38 on: 18 December 2017, 22:08 »
I thought it was a MK7 GTI mudflap on a MK7.5 GTD that needed trimming, this makes my brain hurt  :grin:
Offline SRGTD
« Reply #39 on: 18 December 2017, 23:08 »
See reply #7 in the thread at the link below;
http://www.golfgtiforum.co.uk/index.php?topic=280898.0
