Author Topic: Buying a polishing machine?  (Read 10045 times)
Offline Booth11
« Last Edit: 07 July 2017, 16:17 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline cyclopops
Re: Buying a polishing machine?
« Reply #2 on: 08 July 2017, 19:50 »
No previous experienc
Thanks for your reply.
Offline cyclopops
Offline MjrSharpe
« Reply #4 on: 11 July 2017, 14:46 »
Most dodo juice products are good, so I'm sure that polisher is too. With it being rotary though there is always the risk of burning/ damaging your paint. For this reason I always stick to a da. I got a kestrel DAS 6 as mentioned and find it more than enough when combined with the right pad/ polish.
2016 GTI - Tornado Red, M52 remap, DTUK Pedal box, dv+, racingline turbo elbow, forge turbo muffler delete, racingline springs, racingline stage 2 BBK, novus 0.1 wheels, injen induction kit ,st rear anti roll bar, TT short shift, 034 motorsports dogbone upper / lower inserts, sachs organic clutch, custom stainless steel exhaust, res delete, leyo bezels, oettinger rear spoiler, maxton splitter, golf r rear lights
Offline SRGTD
« Reply #5 on: 11 July 2017, 15:33 »
What are people's thoughts on this one?
http://www.cleanyourcar.co.uk/machine-polishing-pads/car-polishers/dodo-juice-spin-doctor-rotary-v2/prod_806.html
Cyclopops, as you've said you don't have any precious experience of using a machine polisher, you'd be much better off getting a dual action (DA) polisher.
As MjrSharpe has said, there is a risk of burning through your paint wth a rotary polisher, especially in inexperienced hands. With a DA machine, I find there's very little, if any, heat build up between the pad and the paintwork, so paint burn-through shouldn't be a risk.
« Last Edit: 11 July 2017, 16:39 by SRGTD »
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Booth11
« Reply #6 on: 11 July 2017, 16:40 »
Echo what the others say.  If you have never machine polished before a rotary polisher is not the best introduction, due to the risk (in inexperienced hands) of a build up of heat and potentially burning through the paint.  On a rotary the head/plate rotates in a fixed orbit so if the pad is against the paint in one place for too long then heat can build up and this can lead to burning paint if not careful. With a DA the head/plate oscillates in a random orbit changing direction which massively reduces the amount of heat that is generated and thus significantly reduces the risk (to pretty much zero) of damaging the paint through burning.  Best to cut your polishing teeth with a DA.
DoDo Juice do offer a DA at a reasonable price - DJ Buff Daddy.  http://www.theultimatefinish.co.uk/dodo-juice/buff-daddy-das-6-orbital-machine-polisher.aspx
http://www.juicydetailing.co.uk/dodo-juice-buff-daddy-dual-action-machine-polisher.html
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline cyclopops
« Reply #7 on: 11 July 2017, 18:13 »
Thank you all fofor the advise
Funnily enough the link Booth11 put the the DA version is the link I was meant to put, but I seemed to have copied the wrong link.
Thanks again.
Offline hepton
  • 2017 GTD
Offline Daz Auto
  • Other brands of washing powder are available.
« Reply #9 on: 27 July 2017, 11:01 »
Just bought my first DA polisher. It was a Katsu purchased from Amazon. It looks identical to one of the Sealey machines and the Argos Challenge Xtreme priced at £57.99. For half the price of a Das6 Pro I though it would do for a starter machine.
10/8/2017 - GTI Performance, Red,5dr DS
