Author Topic: Bits on your new 7.5?  (Read 11079 times)
Offline Mk1Macca
« on: 30 June 2017, 21:55 »
Silly questions for anyone else that's got a new 7.5...
The rear seat isofix points, did you get plastic covers for them? My last GTD had covers, as did the 1.6 TDi that we had. The new GTi doesn't.
Did you get a plastic boot liner and safety kit (2 x high vis, first aid kit, triangle), or, as I suspect, we just got lucky and the dealer put them in by accident?
Offline Shearer9
Re: Bits on your new 7.5?
« Reply #1 on: 30 June 2017, 23:02 »
I had same questions after picking up mine a couple of months ago.
There is no isofix plastic covers on the rear seats in the 7.5, at least on UK version. They have painted the bars red in the GTI though. (Nice touch).
I found the accessories pack was depending on what dealer I used. My last 2 golfs haven't had them.
Offline JoeGTI
« Reply #2 on: 01 July 2017, 01:04 »
That's odd!
The plastic covers on the isofix points are definitely there on any MK7 I've been in.
I sat into a couple of 7.5's in showrooms and the first thing I noticed when opening the drivers door were the large and obvious exposed metal bolts on the inner door frame that hold on the door mirror. Those bolts are also covered by a black plastic cover on the MK7.
Sounds like it's yet more cheeky cost shaving by VW.
Offline fredgroves
« Reply #3 on: 01 July 2017, 08:28 »
Wasn't there something else they had previously chopped on latter Mk7's?
Some other sort of plastic cover... was it rear seat hinges or something?
Anyway it was something which I thought "must remember to remove those from my Mk7 when it goes back to reuse".... and then forgot.
Offline I wanted a GTi
« Reply #4 on: 01 July 2017, 12:42 »
Yeah a bit of plastic to cover the rear seat mount point.
Offline Sootchucker
« Reply #5 on: 01 July 2017, 14:53 »
Might have been me. It's the first thing I noticed when I picked up my May 2016 GTD in comparison to the outgoing September 2013 GTD. Deffo cost cutting by VW following the Dieselgate debacle.
Offline JoeGTI
« Reply #6 on: 01 July 2017, 15:01 »
That's the missing cover I mentioned above! I thought it looked crap when I sat into a new MK7.5, so it sounds like they dropped that cover quite a while ago? My August 2015 R has that cover over those bolts so it must have been deleted in 2016 at some point... You'd wonder what the hell they save by deleting little things like that. Pennies per car surely? I guess it all adds up if you're shifting thousands of them.
Offline Briggsy
« Reply #7 on: 01 July 2017, 16:09 »
Exactly that, when you're producing 7 digit volume of cars and can cost cut things like that it adds up real fast, allows the money to be spent elsewhere, it just depends on what they decide that elsewhere to be.
Offline fredgroves
« Reply #8 on: 01 July 2017, 16:33 »
I think those changes came with the MY17 swapover ~May 2016
Offline maxie
« Reply #9 on: 01 July 2017, 17:31 »
they could at least color code the screws. or use black ones as the silver just makes it look cheap...
