Author Topic: Turbo issues maybe...  (Read 14552 times)
Offline paradisiac82
  • 2003 Golf MK4 GTTDI ARL (PD150)
Re: Turbo issues maybe...
« Reply #30 on: 25 June 2017, 22:48 »
If its popping its over fuelling. You can cycle the lambda.
Or if you live data you should be able to check co levels and such.
This is a sh!t explanation. Haha
Yeh I just don't get how it's saying it's running lean yet throwing fuel into the exhaust it's crazy
Offline lemski
  • 16v
« Reply #31 on: 26 June 2017, 21:03 »
Swap the injectors if you have spares. Can you live data the lamda cycle?
« Reply #32 on: 30 June 2017, 18:53 »
Fitted new MAF and all good now. ESP light is still on permanently, only 2 fault codes are G200 and Brake Switch
Offline lemski
  • 16v
« Reply #33 on: 30 June 2017, 21:12 »
Maf sensors. Pesky things but it helps fuelling.
Atleast its sorted though mate
« Reply #34 on: 30 June 2017, 21:29 »
yeh really happy :) ........now to make it FASTER!!!!!
Offline Manford
« Reply #35 on: 11 July 2017, 09:12 »
Sorry to jump on your thread, couldn't work out how to send you a message?
How do you get the graphs and logs I've been looking through vcds lite and I cant see how you do it?
I had similar issues on my wrx a few years back and want to be able to extract the same info out the golf.
Took it out for a run and with stock DV there was no apparent hesitation and these were my logs. Is it bad the actual is higher than the specified even though its not by a lot?
