Author Topic: Mk2 golf gti 16v 1.8turbo conversion  (Read 9086 times)
Offline Rmilne1990
Re: Mk2 golf gti 16v 1.8turbo conversion
« Reply #10 on: 29 May 2017, 14:31 »
Offline Rmilne1990
« Reply #11 on: 29 May 2017, 14:39 »
Engine is for sale I have a video of it running it's a bit lumpy on idle as I don't have a timing light, another messy mk2 engine bay
« Last Edit: 29 May 2017, 14:40 by Rmilne1990 »
Offline lemski
  • 16v
« Reply #12 on: 29 May 2017, 16:29 »
There is a forsale section down the page somewhere. On the running rough on idle they all do a little bit. Normally an airleak
Offline Rmilne1990
« Reply #13 on: 07 June 2017, 22:12 »
[/URL][/img]
So I made a start to stripping more out the interior and removing the wiring loom  :sick: I don't know who wired up the golf before me but the wiring is a mess with bridge wired here there and everywhere. A lot still do before I can get her welded up and sprayed but it's always a bit less  :wink:[/URL][/img][/URL][/img]
« Last Edit: 11 June 2017, 22:16 by Rmilne1990 »
Offline Rmilne1990
« Reply #14 on: 07 June 2017, 22:14 »
 so much bloody bridge wires 🤦🏻‍♂️
« Last Edit: 07 June 2017, 22:16 by Rmilne1990 »
Offline Rmilne1990
« Reply #15 on: 07 June 2017, 22:17 »
Roof liner out
Offline Rmilne1990
« Reply #16 on: 11 June 2017, 22:15 »
So today has been a mixture of good and bad il start with the good  :grin: so I got the engine and gearbox out the golf all went smoothly apart from one of the rear engine mount bolts snapping which ended up in the mount being removed from the back of the engine instead
After getting the engine out I decided to start removing some of the easy stuff such as horn, wings and some of the wiring everything has been marked up so far to help when it comes to merging the two wiring looms a job I am not looking forward to  :sick:
« Last Edit: 11 June 2017, 22:17 by Rmilne1990 »
Offline Rmilne1990
« Reply #17 on: 11 June 2017, 22:39 »
Also got pretty much everything stripped out the inside now de little bits to come out but getting there  :smiley:
A fine example of some poor repair work
Found some more rust that I didn't know about once you knock don't stop  :shocked:
