Author Topic: Golf Gti PP problems somone help 😥  (Read 6080 times)
Offline CHB100
Re: Golf Gti PP problems somone help 😥
« Reply #10 on: 23 May 2017, 16:36 »
Surely any small issue gets exaggerated, the more load. I'd guess it's one or more bush kit knackered, is it one side only?
Arrived 15/5/17 Mk 7.5 R Lapiz 5dr DSG, Prets, Pan Roof, DCC, Rear View Cam.
Our other car is a Mk7 GTI DSG 5dr Tungsten, Vienna, Rear View Cam, Park assist.
Offline gtiaps
« Reply #11 on: 23 May 2017, 18:30 »
I run 20mm rear and 15mm front spacers on standard 19" santis and TBH iv had no issues at all.
When I had my 16"x7" winter alloys on same again no issues although my winter set does have spigot rings
2010 Candy White Scirocco 2.0 TDI
2016 Carbon Grey Gti 2.0 Fully Loaded
COLLECTED 29/4/2016 and well pleased with the GTI😆😆
Offline Don76
« Reply #12 on: 23 May 2017, 20:01 »
It can't be anything wrong with the car if there's no issues with the standard set up.
Sounds like bad luck with your choice of mods.
Offline Tjmarbs
« Reply #13 on: 24 May 2017, 09:41 »
So this morning the wheel bearings gone... maybe this was the issue
Offline Tjmarbs
« Reply #14 on: 24 May 2017, 09:45 »
Ive looked on other forums and it seems to be a common problem front left bearing going at low miles. All around 20-30k exactly the same as mine. Booked into dealership friday hopefully it will be covered under warrenty because i don't see how this has happened when i have done no different than any of my freinds with the same cars, if anything i have done nothing too my car in comparison. It's serviced and maintained to a high standerd always.
Online Watts
« Reply #15 on: 24 May 2017, 10:00 »
I had a rear wheel bearing replaced earlier this year though quite likely due to pothole damage since both wheels on that side were buckled...
Previously:
Offline Gnasher
  • Formerly GnasherVXR
« Reply #16 on: 25 May 2017, 14:22 »
Bugger - coming up to 20k and I've run over half of those on lowered suspension and aftermarket 19s lol. Hopefully I miss out on the wheel baring replacement joy!
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
Offline mcmaddy
« Reply #17 on: 25 May 2017, 19:41 »
My front left wheel bearing went at 1100 miles!!
