Author Topic: Advice needed on cleaning Golf R tailpipes  (Read 17347 times)
Offline adekil
Re: Advice needed on cleaning Golf R tailpipes
« Reply #10 on: 17 April 2017, 19:37 »
As above, Mothers Mag and aluminium polish is excellent.
https://www.amazon.co.uk/Mothers-Mag-Aluminium-Polish-5oz/dp/B00068GEJM
I pre-wash with a few squirts of Bilberry Wheel Cleaner, then they get washed along with rest of car - snow foam, 2 bucket wash but I use a dedicated wheel woollie on the pipes which helps to shift the carbon (shoved in the pipe and rotated around). Finally, they are polished up with Mothers Mag and Aluminium Polish and buffed to shiny with a plush microfibre.
Bilberry is good for shifting loose soot but for baked on soot you need to work a good metal polish into it or if really baked on, a little metal polish on some fine grade 0000 steel wool worked around the perimeter of the pipes (not on the outer parts as will scratch) shifts it. Be very careful with the steel wool, as it can dull down the chrome.  Then polish to a high shine with metal polish.
https://www.amazon.co.uk/Liberon-Metre-Length-Ultra-Grade/dp/B01B7XBQIS/ref=sr_1_1?ie=UTF8&qid=1492452842&sr=8-1&keywords=0000+steel+wool
Once you've got the baked on soot, keep on top of them, regular cleaning is the key to it.
Thank you Booth11 - which wheel mitt do you use or recommend just for the pipes? I'm going for the direct Mothers Mag after a quick wash to see what comes off before I start buying up Amazon  :wink:
Current(2024): MK8 Golf R, Pure White, RV Camera & 19" Estoril Diamond Cut
Offline Booth11
« Reply #11 on: 17 April 2017, 20:26 »
On wheels I use wheel woolies and a wheel mitt, and both are good for tailpipes.  I use these wheel mitts. And you can get 20% forum discount using code GTIFORUM20 https://wo-wo.co.uk/collections/wo-wo-car-detailing-products/products/microfibre-wheel-wash-mitt
And I also use the big sized wheel woolie (of the 3-piece set) on my tailpipes. http://www.cleanyourcar.co.uk/wheels-and-tyres/wheel-woolies-wheel-brush-kit/prod_1037.html
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline david25
« Reply #12 on: 01 May 2017, 09:50 »
I prefer something milder on chrome plating
Now = 2011 MK6 GTI - Reflex Silver
Past = 2006 MK5 GTI - Tornado Red and Solid Black
Offline LRWmotorsport
« Reply #13 on: 02 May 2017, 08:09 »
I used good old fashioned Autosol.
2015 BRSCC PGTI Championship 2nd #55
2016 BRSCC PGTI Championship 2nd (again) #25 & BARC Intermarque
2017 BRSCC PGTI CHAMPIONS #24
Offline juggler
« Reply #14 on: 02 May 2017, 19:14 »
Scrunch up kitchen foil into a ball and use it instead of wire wool. Works a treat.
1976 Mini 1275GT
1983 MK1 Fiesta XR2
1988 Escort RS Turbo
1996 MGF VVC
2001 E46 2.5 Conv
2002 Impreza WRX
2004 E46 M3
2012 500 Abarth
2013 Punto EVO Abarth Supersport
2016 MK7 GTI
Offline 7MAT
« Reply #15 on: 12 July 2017, 08:52 »
Britemax Metal Twins for the win!
Use #1 (Easy Cut) to polish and clean, #2 (Final Shine) to fine polish and protect.
https://www.britemax-direct.co.uk/metal-polish-c102x2778536
Liquid based product which contains actual cut instead of the usual cream based sovent cleaners
MK7.5 Golf GTI Performance, 3 door, Issac Blue, DCC, Manual. Racingline Stage 1 OEM+, Remus Exhaust system, Sache Performance Clutch.
« Reply #16 on: 18 July 2017, 21:37 »
Autosol for the win.
Offline 7MAT
« Reply #17 on: 21 July 2017, 09:52 »
Nice little video from Wo-Wo showing the Britemax Metal Twins in action!
https://www.youtube.com/watch?v=r0oHC1WbMGA&t=39s
« Reply #18 on: 21 July 2017, 11:50 »
Didn't notice I'd chipped in with my suggestion twice.
Apologies, I'm not on commission.
Offline Booth11
« Reply #19 on: 21 July 2017, 12:59 »
I think you should go third time lucky.  :laugh:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
