Author Topic: HELP with my 1.8 t  (Read 5655 times)
Offline caddy
Re: HELP with my 1.8 t
« Reply #10 on: 19 April 2017, 11:59 »
ok will have a look.its really doing my head in :angry:
Offline Mr_Orange
« Reply #11 on: 19 April 2017, 20:04 »
As I recall you can also roughly test the dv too; push the inner cylinder in, cover the small vac line attachment with your finger tip and release the cylinder, it should pull a vacuum and slowly retract ;-)
Build thread clicky
Offline caddy
« Reply #12 on: 19 April 2017, 21:02 »
thanks try that and dv all good.one of the pcv crankcase check valve is bad so change that tomos and see it gose
Offline Jordan_gti
« Reply #13 on: 18 May 2017, 11:06 »
Don't mean to throw another spanner in the works, but have a good rummage around all of your vacuum pipes, its amazing how many deteriorate with age, I've replaced lots of mine due to this & It seemed to be fine at first glance. Its also amazing how many errors a car can throw with vacuum leaks, its worth a go for the sake of some 3mm Vacuum hose
2002 Golf Gti 1.8T (AUM) LC9Z
