Author Topic: Powder coat santiagos  (Read 15180 times)
Offline Sandtrap
« on: 19 March 2017, 01:00 »
My santiagos are un marked but i want a slight change .  should i powder coat them at a cost of £320 or buy a set of 19" cades appolo £650, and keep santiagos aside as they are, for selling car in future ?
Or other option, leave leave the santiagos as they are and stop wanting to change stuff all the time !
« Last Edit: 19 March 2017, 01:13 by Sandtrap »
2014 GTI Performance
2012 Golf R DSG
2010 GTD
2008 GTD
2007 GTI
Offline SRGTD
Re: Powder coat santiagos
« Reply #1 on: 19 March 2017, 08:41 »
Forum member EricM had his Santiagos powder coated in smoked chrome colour. I think they look good, and having them powder coated does away with the potential problem of white worm corrosion that diamond cut alloys are prone to. Link to thread, including picture below;
http://www.golfgtiforum.co.uk/index.php?topic=278775.0
I see that the Cades Apollo wheels are available in a number of different offsets and 2 different widths; 8.5" and 9.5". The spec for your Santiagos is 5x112 bolt pattern, 19" diameter and 7.5" width with an offset of ET51.
Assuming you'd be planning on getting the 19x8.5 version of the Apollos, the offset is ET40 for your bolt pattern of 5x112, which would mean the inner and outer clearance would change by;
Inner clearance; 2mm less
Outer clearance; the outer face of the wheel would stand out 24mm more than your current wheels, so almost an inch closer to the wheel arch edge. Bear in mind that you'd need wider tyres on an 8.5" wide wheel, which would likely add a few extra mm's to the 24mm additional 'poke', so you may have rubbing issues with the tyres fouling the bodywork (if you're lowered). Would an extra 24mm-plus additional tyre width extend the tyres beyond the bodywork? If so, I think that might be an MOT fail. Link to wheel offset calculator below so you can see the impact that different offsets will have on wheel clearance;
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
If your current wheels are unmarked, I think I'd stick with them and save yourself the cost of powder coating or buying wider wheels/tyres that might give you clearance issues.
« Last Edit: 19 March 2017, 09:54 by SRGTD »
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Watts
« Reply #2 on: 19 March 2017, 16:53 »
If they're unmarked I'd leave them as is. For a small change, how about swapping the centre caps for the ones with a red circumference (depending on the colour of your car):
https://www.kunzmann.de/shop/en/wheels-wheel-hub-cap-chrome-red-vw-golf-7-genuine-volkswagen.htm
Or a change of wheel if you have a capacious wallet! I covet the AEZ Raise, possibly as they have a similar design to the Santiagos but for me I'd go 18" to reduce the chance of damage from pot holes and cheaper tyres as I'm a tight a**e :whistle:
http://www.aez-wheels.com/EN/products/raise
Previously:
Offline Sandtrap
« Reply #3 on: 20 March 2017, 12:38 »
Thanks for input .. I think ill keep the santiagos on the car. might still powder coat but also might wait for that until they actually need it ..
2012 Golf R DSG
2010 GTD
2008 GTD
2007 GTI
Offline Zack
« Reply #4 on: 20 March 2017, 15:54 »
£320 is very expensive, I had 4 powder coated last year for £200 and very good finish.
Offline brettblade
« Reply #5 on: 20 March 2017, 16:17 »
£80 per wheel for high quality faces and barrels on 19s isn't particularly expensive, I'd say that's the going rate.
Orded 04/06/2016
Build W/C 01/08/2016
Handover 01/09/2016
GTI PP, CSG, Tech pack, parking pack, 90% tints, DCC, 19" Santiago alloys
Soon to be gone!
7.5R Indium Grey, 19” Spielbergs expected 01/03/2019.
Offline Zack
« Reply #6 on: 20 March 2017, 18:31 »
Not the going rate if I'm paying, the powder coaters that I use are in your neck of the woods. :smiley:
Offline Sandtrap
« Reply #7 on: 20 March 2017, 20:03 »
£320 is for smoked chrome . Basic colours are £270  abd theses prices are for just dropping car off and they do it all !  So i think thats not too bad
2012 Golf R DSG
2010 GTD
2008 GTD
2007 GTI
Offline Sandtrap
« Reply #8 on: 31 March 2017, 18:34 »
Got the car back today with the Santiagos done in anthracite !  Happy with the outcome ... apart from the plonkers painting my centre caps to match ! I was not amused when I saw that .. but after some too and frow they agreed to deduct the cost of replacements ..
excuse the state of the  car ! I'm just back from the wheel place ... got new centre caps ordered and next job is some detailing ....
[/URL]
« Last Edit: 31 March 2017, 18:44 by Sandtrap »
2012 Golf R DSG
2010 GTD
2008 GTD
2007 GTI
Offline Mr GTD
« Reply #9 on: 31 March 2017, 21:01 »
Looks good  :cool:
Bloody numpties doing centres too  :laugh: but at least you got them to cough up for it.
Be good to see some pics of the car in full so we could get a better picture of what it looks like.
It's does look like they've done a good job though!
