Author Topic: Golf AKL questions  (Read 3898 times)
Offline mike1990
Golf AKL questions
« on: 06 January 2017, 09:20 »
Hello
I have forgotten where this Earth strap goes to
https://www.dropbox.com/s/36iikf0zhe6s281/Photo%2027-12-2016%2C%2014%2049%2020.jpg?dl=0
Etka is saying it goes to the TB but I cant remember where on the TB
Thank you
« Last Edit: 07 January 2017, 15:15 by mike1990 »
Offline lemski
  • 16v
Re: Golf AKL earth strap
« Reply #1 on: 06 January 2017, 19:27 »
Anywhere thats metal and itll bolt to. Its only so long so wont be to far out. Should be a stud sticking out without a nut at looks of it
Offline mike1990
« Reply #2 on: 06 January 2017, 23:15 »
Okay thank you. I'll have a look, the car cranking but not starting because this isn't connected
Offline mike1990
Re: Golf AKL questions
« Reply #3 on: 07 January 2017, 15:16 »
Any idea how I'll get the bolt to the coolant flange back in? The one closer to the back of the engine, stupid metal clip or something in the way right over the bolt hole
Offline lemski
  • 16v
« Reply #4 on: 07 January 2017, 16:21 »
Is the metal got a hole in it? If not can it be moved or persuaded to move so bolt can go in
Offline mike1990
« Reply #5 on: 07 January 2017, 16:31 »
yes got a hole in it, but the metal is further away from the coolant flange bolt hole so the bolt won't bite into the head because of it
Offline lemski
  • 16v
« Reply #6 on: 07 January 2017, 16:43 »
Have you tried pushing the metal with a srewdiver or something the trying the bolt. As soon as it bites itll go.
Or look at the metal clip and see if its being pushed out because something behind
Offline mike1990
« Reply #7 on: 07 January 2017, 17:42 »
I'll try pushing it out the way and I've also rebuilt the engine
Engine back together and running
Still can't get that Earth strap anywhere as I don't know where it would go.
Engine got a misfire(probably the earth strap)
Dropbox - File 07-01-2017, 13 52 37.mov
Dropbox - File 07-01-2017, 13 56 32.mov
another video
Revving - video
That noise seems to go away when the engine revving. That misfire needs sorting out. Compression tested the engine and it read about 195-200 on all
What you's think?
« Last Edit: 07 January 2017, 18:53 by mike1990 »
Offline lemski
  • 16v
« Reply #8 on: 07 January 2017, 19:18 »
Cant look at photos or video so cant say. Compressions good though across the board.
