Author Topic: golf 7 gti xenon afs coding problem  (Read 5072 times)
Offline kenney88nl
« on: 17 December 2016, 19:22 »
Heey,
I have a golf 7 gti from 2013 with original xenon lights without leds. I replaced the headlights with bi-xenon and leds. I have bought a cable set and AFS module at Kufatec. Everything is fitted properly and Kufatec says to transfer the old coding from the xenon range to the new. It doesnt work it says error 34. Am I doing something wrong? Below is the car log.
Thanks on advance.
Monday,12,September,2016,15:00:33:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWZZZAUZEW016075   License Plate:
                Address 55: Xenon Range       Labels: 7P6-907-357.clb
Control Module Part Number: 7P6 907 357 D    HW: 7P6 907 357 A
  Component and/or Version: AFS-ECU       H07 0090
           Software Coding: 069202104F000200
            Work Shop Code: WSC 00028 028 00068
              ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120 (VW37)
                      VCID: 40855840DB7D021ED43-8015
7 Faults Found:
5276144 - Power Output Module for Left Headlamp
          C1081 F0 [137] - Not Coded
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 215
                    Mileage: 29801 km
                    Date: 2016.09.12
                    Time: 14:57:28
5276400 - Power Output Module for Right Headlamp
          C1082 F0 [137] - Not Coded
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 215
                    Mileage: 29801 km
                    Date: 2016.09.12
                    Time: 14:57:28
13678592 - Local Data Bus
          U10B8 00 [137] - Defective
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 215
                    Mileage: 29801 km
                    Date: 2016.09.12
                    Time: 14:57:28
13705473 - Databus
          U1121 00 [137] - Missing Message
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 215
                    Mileage: 29801 km
                    Date: 2016.09.12
                    Time: 14:57:28
13705730 - Databus
          U1122 00 [137] - Implausible Message
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 215
                    Mileage: 29801 km
                    Date: 2016.09.12
                    Time: 14:57:28
13705478 - Databus
          U1121 00 [009] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 215
                    Mileage: 29801 km
                    Date: 2016.09.12
                    Time: 14:57:28
13705479 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 215
                    Mileage: 29801 km
                    Date: 2016.09.12
                    Time: 14:57:28
Thursday,06,October,2016,15:44:22:65217
                Address 55: Xenon Range       Labels: 5Q0-907-357.clb
Control Module Part Number: 5Q0 907 357     HW: 6R0 907 357 A
  Component and/or Version: LWR-ECU       005 0070
           Software Coding: 029A010001000000
            Work Shop Code: WSC 01357 011 00200
              ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110 (VW37)
                      VCID: F5EB7994543F77B6375-80A0
3 Faults Found:
5276949 - Positioning Motor for Headlight Range Left
          C1085 15 [137] - Open or Short to Plus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 18
                    Mileage: 31643 km
                    Date: 2016.10.06
                    Time: 15:42:14
5277205 - Positioning Motor for Headlight Range Right
          C1086 15 [137] - Open or Short to Plus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 18
                    Mileage: 31643 km
                    Date: 2016.10.06
                    Time: 15:42:14
13705478 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 18
                    Mileage: 31643 km
                    Date: 2016.10.06
                    Time: 15:42:12
Wednesday,14,December,2016,10:35:11:65217
           Software Coding: 069202106F000200
7 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 158
                    Mileage: 36556 km
                    Date: 2016.12.14
                    Time: 10:33:44
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 158
                    Mileage: 36556 km
                    Date: 2016.12.14
                    Time: 10:33:44
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 158
                    Mileage: 36556 km
                    Date: 2016.12.14
                    Time: 10:33:44
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 158
                    Mileage: 36556 km
                    Date: 2016.12.14
                    Time: 10:33:43
13705473 - Databus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 158
                    Mileage: 36556 km
                    Date: 2016.12.14
                    Time: 10:33:43
13705478 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 158
                    Mileage: 36556 km
                    Date: 2016.12.14
                    Time: 10:33:43
13705479 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 158
                    Mileage: 36556 km
                    Date: 2016.12.14
                    Time: 10:33:43
Offline golfhappy
Re: golf 7 gti xenon afs coding problem
« Reply #1 on: 17 December 2016, 20:45 »
Have you tried here? http://www.ross-tech.com/vag-com/cars/xenonalignment.html do you own a cable? can you post the auto scan with them?
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
Offline vidman2
« Reply #2 on: 18 December 2016, 10:33 »
Suggest you upgrade to the latest version of VCDS as the older versions do not properly support the MK7, if you have a clone cable you will not be able to update as only genuine cables can be used with the updated S/W.
2015 R DSG. Limestone Grey, DCC, Winter Pack, Tech Pack, Reversing Camera    plus   2013 Mk7 GTi DSG - Performance, Navigation, Winter Pack, DCC, Park Assist,
