Golf mk2
MK2 8v GTI dying after starting up after 2 years
Topic: MK2 8v GTI dying after starting up after 2 years (Read 10720 times)
lemski
Forum addict
16v
Re: MK2 8v GTI dying after starting up after 2 years
Reply #10 on:
19 December 2016, 17:51 »
Take the airfilter out. Or off see if it still does it. Had a rangerover in that had a mostly blocked air filter and that use to suck the intake pipe closed because it couldnt get the air.
turfandy
Reply #11 on:
20 December 2016, 17:30 »
Yes, tried taking the pipe off completely, still does the same not connected to the air filter, just that there's nothing to see. Haven't been in touch with the garage yet as can't get it there at the moment.
Brighouse-gti
Here all the time
Reply #12 on:
20 December 2016, 21:43 »
Bit of a stab in the dark but are all the timing marks lining up correctly?
turfandy
Reply #13 on:
21 December 2016, 17:08 »
Hopefully may have sorted it, won't know till I get it back together in a couple of days. I took the rocker cover off and the breather gauze was completely blocked with solidified oil, if it's not that it's something else crossed off the list. Only down side is one of the cam cover bolts was already sheared off inside the head. I've read that if you put a rubber gasket on you have to change the bolts/studs, how do the old ones come out.
lemski
Forum addict
16v
Reply #14 on:
21 December 2016, 17:18 »
Use a stud extract or 2 nut locked together should pull the studs out. Ive never changed either when changing a rocker gasket ever... But doesnt mean its not suppose to be done
Thats sound like it could do it as the engine cant breath sufficiently.
bodga
Here all the time
F reg GTI 16v
Reply #15 on:
22 December 2016, 04:06 »
Take the air filter out and try it? Or it could be the exhaust pipe is blocked?
alexperkins
Reply #16 on:
23 December 2016, 12:29 »
Quote from: turfandy on 21 December 2016, 17:08
You will need to change them, as the cork studs have a collar wheras the rubber studs are slightly longer and are smooth
turfandy
Reply #17 on:
23 December 2016, 16:44 »
Any idea how the old ones come out
turfandy
Reply #18 on:
28 December 2016, 16:03 »
Nearly ready to try again, cam cover cleaned out, painted, rubber gasket and new studs on, new breather gasket, ran out of time to finish putting everything back together. Try it tomorrow. If it runs then can start on sump gasket.
turfandy
Reply #19 on:
29 December 2016, 18:17 »
Still the same, gutted.
Golf mk2
