Author Topic: Problems!..2.0, 8V gTI  (Read 22981 times)
Offline Syko
Re: Problems!..2.0, 8V gTI
« Reply #10 on: 14 December 2016, 12:54 »
Service book, equipment sticker in boot or sticker on cambelt cover.
Appears to be AGG .
I have no replaced both no.30 & 18 relays, no change.. :undecided:
many thanks
Offline itavaltalainen
« Reply #11 on: 14 December 2016, 18:49 »
Crankshaft sensor ?
Did it show any fault codes?
Offline Syko
« Reply #12 on: 15 December 2016, 09:21 »
Crankshaft sensor ?
How to tell if its the crankshaft sensor?
Offline lemski
  • 16v
« Reply #13 on: 15 December 2016, 09:58 »
Crankshaft sensor ?
Itll not start. Or start and randomly cut out when you dip the clutch. Generally not running right because it cant pick up where the. Crank is
« Reply #14 on: 15 December 2016, 15:44 »
Crankshaft sensor ?
Offline Syko
« Reply #15 on: 31 December 2016, 11:34 »
Crankshaft sensor ?
Ok, Thanks
current status is
Engine turns over but doesnt fire
Replaced relays 18 & 30 - no change. Relay clicks when key turned
No warning lights come on when key turned to 'on'.
Do i go to a replacement crank sensor from here? Thanks
-sorry, but i am fishing in the dark, and have zero comprehension of electrics :rolleyes:
Offline lemski
  • 16v
« Reply #16 on: 31 December 2016, 12:41 »
Have u scanned it.
Checked for a spark.
Offline Syko
« Reply #17 on: 01 January 2017, 14:06 »
Have u scanned it.
Not scanned. What scanner do i use?
Will double check plug spark
The lack of dash lights/display should be a simple prob, surely?
Thanks for bearing with me
Offline lemski
  • 16v
« Reply #18 on: 01 January 2017, 18:30 »
Bulbs gone out. Earth.
Without a pic of the dash its hard to see what you mean.
No ign lights ie nothing on the dash works.
Should be a obd2 scanner on a mk3
Offline Syko
« Reply #19 on: 02 January 2017, 11:38 »
No, nothing on the dash seems to work
Are those scanners easy to find?
