Author Topic: Pd150 egr valve and cooler removal  (Read 4967 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Pd150 egr valve and cooler removal
« Reply #10 on: 28 November 2016, 22:07 »
With that said, if you're adamant you want to get rid of it then i wouldn't buy it from Darkside as they charge well over the odds for what is essentially a piece of tube.
You can buy the same thing from China on Aliexpress for about a tenner!
As for the cooler delete then do as i did and buy it directly from TPS, if you cant get anything out them then try the main dealer using the part number on the Darkside website.  :wink:
Offline Ajamesc
« Reply #11 on: 02 December 2016, 17:19 »
I'm going to put my bore scope up inlet and see if it's clear if not strip that and the manifold and clean it I'm thinking if it works as it should I may as well leave it on. Just got a full miltek de cat system with the descret tail pipe for 200 quid result so I'll fit that after work on Monday and have a look at it
