Author Topic: 1999 golf mk4 gti 1.8 t wiring fault  (Read 2055 times)
Offline Azza1234
« on: 24 November 2016, 21:22 »
Took clocks out my car and a pin got bent and touched another one I unbent the pin but now have no permanent live on the cluster pin 23 blue connector I've run a 12v preferment live from my stereo to the cluster just so I can use the car does anyone know where the fault would be I checked the fuses and there all ok the problems with terminal 30, (B+) wire any ideas?
Offline itavaltalainen
Re: 1999 golf mk4 gti 1.8 t wiring fault
« Reply #1 on: 24 November 2016, 21:27 »
Pin bent in cluster?
Offline Azza1234
« Reply #2 on: 24 November 2016, 22:11 »
Yep I only relised after I was rushing to get the connectors back in but have bent it back now but there's no voltage on the loom side of the car which should give 12v permanant
« Reply #3 on: 24 November 2016, 22:16 »
Have you replaced fuse for dash?
I would do that before anything else, could have just triggered and you may not be able to spot with your eye.
Send me a PM with your email,..... might be able to send you a wiring diagram if I dig out my old laptop with VW stuff on.
Offline Azza1234
« Reply #4 on: 24 November 2016, 22:55 »
Just checked the dash fuses again found a 5amp blown replaced it and all working again thank you for your help can't believe I missed it earlier
