Author Topic: The CS-S delivery thread  (Read 137152 times)
Offline volkswizard
Re: The CS-S delivery thread
« Reply #250 on: 05 December 2016, 17:19 »
No spare.
I need to talk to the dealer as I appear not to have a towing eye or wherl cap hook or anything.
Towing eye may be worth while if you don't get the tyre foam stuff either?  If not I am surprised the car can leave a VW dealer without something to help in the event of a puncture, no matter how good or bad they are whether its space saver or tyre foam. If you get/need a spare I guess it will need to be secured someway or another.
It comes with breakdown cover at least, I will be getting a can of tyre foam.
No towing eye on any car let alone a track biased car is a bit of an oversight.
Can anyone confirm the lashing eyes are there for a luggage net? I'd be surprised if one wasn't supplied considering there is no parcel shelf to keep things contained during a roll over.
Offline vipergts
« Reply #251 on: 05 December 2016, 17:19 »
You know this "ring/race" setting is niggling me.
The ring setting was set to give a bit of compliance because of the undulating surface, it needed a bit more compliance.
Therefor, race mode cannot be ring mode as for a dry circuit the surface would be spot on and a harder setting would be required.
Offline vipergts
« Reply #252 on: 05 December 2016, 17:21 »
Yes there's 4 lashing eyes for the net
Offline volkswizard
« Reply #253 on: 05 December 2016, 17:54 »
jjgreenwood reminded us yesterday that whatever "'ring" mode there is, is actually accessed via Individual mode.
In Individual you can adjust the settings for the engine, (fake) engine sound and also DCC suspension and more.  What jjgreenwood said quoting what Dan Trent said on the Pistonheads video was that if you reset the settings in Individual mode, THIS is the settings used for the 'ring.
This means you can still use RACE mode which will have DCC at its firmest and you can still choose the hardest DCC setting in Individual mode but this wont be "'ring" mode
Here's the video,  fast forward to 4 mins 30 secs, you will see that when he presses reset, most things go to RACE but DCC actually goes to COMFORT, bit of a surprise!
https://www.youtube.com/watch?v=b27H2q_4ITQ&t=246s
« Last Edit: 05 December 2016, 18:03 by volkswizard »
Offline clubsport
« Reply #254 on: 05 December 2016, 18:03 »
Volkswizard, I went through the set up with Viper yesterday, I am reasonably competent with the set up and modes, neither of us could find "ring" mode distinct from the "race" setting. We Even tried again with the stability system switched off to see if that was a way in?
I have sent Viper contact details for VW's "product manager", maybe he can shed some light on the mysterious mode?
Offline volkswizard
« Reply #255 on: 05 December 2016, 18:04 »
I've edited the post you replied to as you were typing, so sorry about that, have a re-read, all should be clear.
The clue is that Dan describes it as 'hidden' and it really is!
Jackie Treehorn
« Reply #256 on: 05 December 2016, 18:45 »
No spare.
so you are gonna need:
Generic tyre foam or a specific VW foam kit with case
little hook for the black caps
alloy bar for safe wheel removal to avoid calipers
locking wheel nut  (don't answer that)
tow hook (or loop as it looks)
Net fixing points? Or locations for trim pieces if you had a false floor? Alternatively you could have a space saver (bit heavy i guess) and wheel kit that sits neatly next to it to hold all the other parts?  See below, (Minus the sub) it would sit neat and tidy without issue in a crash, and you lift the lot out when on track.
P1010114 by Emmber, on Flickr
The Ring setting would niggle me too.  Most of the other stuff I would happily do without but on a car built purely from that time and so heavily advertised (rightly so)  I think the absence of the mode setting would bother me too.. I guess it would put dampers in comfort mode? and the engine, steering etc in Sport?  (if it has active dampers)
« Last Edit: 05 December 2016, 18:56 by Jackie Treehorn »
Offline vipergts
« Reply #257 on: 05 December 2016, 19:02 »
STOP PRESS......STOP PRESS
I've found the hidden bit
As Volksman correctly said
In individual,  Paul, yesterday we had trouble finding reset, it doesn't scroll down easily it would seem.
When reset it turns everything to race except suspenders which goes to comfort
Also I have discovered it does in fact have the courtesy light (or whatever they're called) the jobbies that turn on when you turn into a side turning. They're positioned in the side of the inner headlamp pointing sideways. Very neat
Offline clubsport
« Reply #258 on: 05 December 2016, 19:14 »
Great news!
I wonder what else is left to discover? :)
I have to say, how bumpy has the road got to be for comfort to be the optimal setting?
As I said, I thought "race" was perfectly acceptable on a B road without noticeable bump steer or tram lining at sensible speeds.
The comfort suspension setting probably comes into it's own nearer record setting speeds, where the "race" may throw you off of the chosen line!?
Offline volkswizard
« Reply #259 on: 05 December 2016, 19:15 »
 :laugh:
