Author Topic: Finally got me a GTD!  (Read 12991 times)
Offline Jonny_D_1987
Re: Finally got me a GTD!
« Reply #10 on: 05 November 2016, 22:29 »
Only thing is, shes been sitting there for over 2 months, car was originally sold but it all fell through. Will need a good run in to strech her legs :)
Offline Restlessnative
« Reply #11 on: 05 November 2016, 22:30 »
Aug 14 with 40k.Big savings to be had!. :cool:
Your right! ;)
Wish i'd done that.But i just simply had to spec that heated front screen and Dynaudio etc!. :grin:
You will love it's mid range punch.It is probably it's best asset. :evil:
« Last Edit: 05 November 2016, 22:33 by Restlessnative »
Current: Golf GTD MK7  3 door manual carbon grey.
« Reply #12 on: 05 November 2016, 22:33 »
Make sure you give the climate control a good work out too.They don't like being idle.Whack it up to the max cold.Get those gases flowing round the system. :smiley:
« Reply #13 on: 05 November 2016, 22:40 »
Oh ill be sure to give her a good blast all round haha I actually read up somewhere about the compressors failing, ill make sure to check the air con has been serviced!
Sounds like yours has a great spec, so hard to find a second hand one with dynaudio, none of the 5 door ones anywhere in NI have it lol
Do the GTD's have any common faults? A few quick searches on here had just mentioned the air con compressor but other than that they seem bulletproof!
« Reply #14 on: 06 November 2016, 16:21 »
Yeah,most of the used ones i've seen for sale have been 5 door manuals in red,black or white with no extras at all.Saying that,they are still loaded with kit you'd pay extra for elsewhere.
I've not heard of anything major to worry about with them.Do not know if they are still reliable when they get to 5 or 6 years old etc.But that's for the next owner to worry about. :grin:
Don't worry if you sometimes hear the fan running on after you switch the engine off.That's part of the DPF regen cycle.
« Last Edit: 06 November 2016, 23:11 by Restlessnative »
« Reply #15 on: 06 November 2016, 22:28 »
I've not heard of anything major to worry about with them.Don't know if they are still reliable when they get to 5 or 6 years old etc.But that's for the next owner to worry about. :grin:
They do have a great spec dont they! They all have xenon as standard also isnt that correct? My old 2.0 TDI 140 always done that haha never ever seen the DPF light on it thankfully!
This will be my 4th Golf, first one with a button handbrake, not sure what to expect! Lol
« Reply #16 on: 06 November 2016, 22:57 »
Yes they have a whole load of kit as standard.Try speccing a BMW and you'll see what i mean.I had an M135i and if you wanted lumbar support for your seat it was extra. :sad:
Yes the xenons are standard and very good they are too.They even do a little levelling check every so often.Up,down,left right.I haven't seen any other car do that.It is good entertainment. :grin:
You'll love the electronic handbrake.It is a very good system (most of the time).Basically you just forget about a handbrake in traffic.The system detects you are temporarily stopped (in traffic) and applies the brake.You see a green 'P' on the dash.Press the accelerator and it releases in a split second.All you have to do is pull up the wee lever. when you park up.Then you see a red 'P' on the dash.Driving off after start up (in the morning) you don't have to touch a thing .It releases itself( as it does in traffic).
Rarely it's a pain in the arse.You go to move forward in traffic and it doesn't release (for whatever reason).
Annoying but only once in a blue moon.
« Last Edit: 06 November 2016, 23:14 by Restlessnative »
« Reply #17 on: 06 November 2016, 23:41 »
Excellent! Thanks for clearning that up with me, I has noticed the little red and green light when i was messing around with the electronic handbrake lol
The xenons will be great for me and my 4am work starts :'(
Tuesday cant come far enough! Will get some more pics up when I pick her up :)
Offline mcmaddy
« Reply #18 on: 07 November 2016, 06:48 »
You don't even need to pull the parking lever switch either. Just let the car do it's thing.
Offline monkeyhanger
« Reply #19 on: 07 November 2016, 08:00 »
A few people do this, they probably don't realise that when you turn the ignition off that the hold switches to handbrake, they put the handbrake on manually before they switch off.
