Author Topic: Clock changing  (Read 5327 times)
Offline p3asa
Clock changing
« on: 01 November 2016, 23:35 »
Does the Golf not adjust the clocks changing automatically?
Our's never changed even although it was set to take the time from the GPS. I had to go into the Time settings and unselect the summer setting.
Offline Booth11
Re: Clock changing
« Reply #1 on: 02 November 2016, 00:07 »
I had to do the same, and remember having to do it last year too.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline kalimon
  • My other car's a van
Re: Clock changing
« Reply #2 on: 02 November 2016, 06:58 »
Same here.
5 DR Mk 7 GTI PP
Offline phope
Re: Clock changing
« Reply #3 on: 02 November 2016, 07:56 »
http://www.golfgtiforum.co.uk/index.php?topic=260248.msg2498858#msg2498858
A tweak with VCDS required - didn't have to change my time last weekend
Golf Mk8 R order cancelled...awaiting company car instead
Tiguan 1.5 Elegance for the wife & dogs
Skoda 1.5 SEL cheap lease special
Offline p3asa
Re: Clock changing
« Reply #4 on: 02 November 2016, 08:54 »
Thanks. As long as it's not just me.  :grin:
Cheers for the VCDS link I'll have a look.
Interestingly after unticking the summer option the GPS is out by 1minute.
Offline KyleB
Re: Clock changing
« Reply #5 on: 02 November 2016, 10:47 »
Yeah I had to do the VCDS tweak too, but interestingly my Mrs. Leon FR (Mk3) already did this without the need for the VCDS tweak.
Offline dippy_x
Re: Clock changing
« Reply #6 on: 03 November 2016, 06:48 »
I have the vcds tweak as well. It makes no sense.  The option is there but not available generally for reasons I guess?
On Order: 02/05/13
GTD: Carbon Grey, Winter Pack, Keyless, High Beam Assist, Park Assist, Rear View Camera, Furry Dice
Collected: 06/11/13
Offline The ANT
Re: Clock changing
« Reply #7 on: 03 November 2016, 09:07 »
Most things that set the time like that receive a signal with the which the clock understands, but the signal is constant throughout the year, unless the clock knows the date and has been told to adjust to winter time it won't do it  (it needs to know the date to know when, not all countries adjust their clocks for winter so it needs to be told to do it, if it can't be told or doesn't know the date, or both it needs to be done manually).
Suffering from a severe and unforgiving case of GTItis
Offline fredgroves
Re: Clock changing
« Reply #8 on: 03 November 2016, 12:51 »
I can understand why it can't change because of the GPS time signal (GPS does send time, but its always UTC - those satellites don't send out special times for particular time zones lol)
On the other hand, my computer (which also receives time in UTC) knows when to change the clock because it also knows that I've told it its UK... if I set it to a US locale it would change the clocks when the yanks do it (which is this weekend coming).
My Golf is also told that its UK - which means the time and date format, the speed and fuel readings and headlight dipping direction are all set to typical UK values... so why not BST/GMT swap overs?
Again, as before, the technology is all software, the car is capable, they just can't be bothered to give you a well thought out product but still charge you thousands for it.
Offline KyleB
Re: Clock changing
« Reply #9 on: 03 November 2016, 14:33 »
It further doesn't make sense though because the software is there and working on the Leon (and I assume the Audi) that uses the same media/computer system.
