Golf mk4
Wazzzer
Replaced Clutch Pedal Help
Topic: Replaced Clutch Pedal Help (Read 2364 times)
Glowstone
19 October 2016, 20:15 »
Hi
I recently replaced a clutch pedal to a Mk4 Golf ( Typical pedal breaking thing) and now the customer is complaining that his Girlfriend is finding the pedal too hard to depress...I located the spring in the correct position ( there only appears to be one way it can go)....any ideas on whats going on there?
Martyn
lemski
Forum addict
16v
Re: Replaced Clutch Pedal Help
19 October 2016, 20:39 »
The spring is im better condition than the previous one. Or was this not changed?
Maybe the actual reason the pedal snapped is because there is too much resistance between the master and slave cylinder
Glowstone
19 October 2016, 20:44 »
Thanks for the reply fella!...
I kept the old spring....when refitting I noted that the spring seat at the bulkhead end can only go in one way.
when testing the operation of the spring with the pedal i noticed the spring bends upwards when the pedal is activated and returns to its normal position when the pedal is released.
I did wonder about the cylinders ..tho the pedal snapped on the pedal cage itself..apparently a common problem
hmm
Last Edit: 19 October 2016, 20:47 by Glowstone
lemski
Forum addict
16v
19 October 2016, 20:51 »
It is a common problem across the mk4 platform.
Done a few for customers and never had one stiffer than before.
Normally reweld the pedal aswell to make it less likely to happen again.
Where abouts is the car. I dont mind swinging by and taking a look. Im only in the f.o.d
2 heads are sometimes better than one.
I could possibly bring another car with the same pedal and see if that spring moves up as you say your cuatomers is doing
Glowstone
19 October 2016, 20:55 »
Thats ace thanks..the car will be back in on Saturday for me to check it if you want to swing by our garage..would be good for a meet up anyways, local bloke and all that
I used to live in the forest of dean the car weill be in cheltenham
Martyn
Last Edit: 19 October 2016, 20:57 by Glowstone
lemski
Forum addict
16v
19 October 2016, 20:58 »
Depends on the time, gotta at some point Saturday go check a jaguar out for somone.
But I dont mind shooting over to have a check.
Pm me a postcode and time.
I can definately get hold of a car to check against then.
Glowstone
Reply #6 on:
19 October 2016, 21:01 »
thanks again fella, I will let you know tomorrow on times etc
lemski
Forum addict
16v
Reply #7 on:
19 October 2016, 21:03 »
Thats fine bud
Golf mk4
Wazzzer
